04-16-2009 03:30 AM - edited 03-04-2019 04:23 AM
We have quite a simple setup, we have a Cisco 880 (192.168.50.1) router which is the default gateway for all client machines. The router is responsible for forwarding ports 80, 443, 1723 and 25.
We want to re route only port 80 to goto a standard adsl modem. (192.168.50.2) so internet traffic only goes to the modem.
interface FastEthernet3
interface Vlan1
ip address 192.168.15.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 125.255.65.225
ip nat inside source list 111 interface ATM0.1 overload
ip nat inside source static tcp 192.168.15.5 25 125.255.65.226 25 extendable
ip nat inside source static tcp 192.168.15.5 80 125.255.65.226 80 extendable
ip nat inside source static tcp 192.168.15.5 110 125.255.65.226 110 extendable
ip nat inside source static tcp 192.168.15.5 443 125.255.65.226 443 extendable
ip nat inside source static tcp 192.168.15.4 1723 125.255.65.226 1723 extendable
Can anyone advise how this can be done? Do I need to create an access list?
Many thanks
04-16-2009 03:51 AM
You need to create Pilicy-Based-Routing based on the HTTP traffic.
It all depends if all traffic or a sub-set of traffic needs to be forwarded.
You also need to think about if the ADSl mode goes off-line, are you happy with no internet access until issue is rectified, or if not - you also need to configure IP SLA.
HTH>
04-16-2009 03:58 AM
all internet traffic that need to be forwarded, but not any other traffic. we can not too concerned if we lose internet access.
04-16-2009 04:01 AM
The PBR (Policy Based Routing) based on an access-list will fit your requirements.
HTH>
