switch/router
Hi gentlemen,
1. How can I remove all my configs on my switch or my router?
2. How can I retrieve my forgotten password on my switch or my router?
3. How can I backup my config on my switch or my router?
Thanks in advance
6 Replies 6
Deepak Kumar
Your answer would be:
 How can I How can I remove all my configs on my switch or my router??
Ans: Switch#wr erase
after that reboot the switch/router without saving running-config to startup-config again. Read all steps very carefully and reload it.
Ans: It depends on the module number of router/switch.
Check out: https://www.cisco.com/c/en/us/support/docs/routers/2800-series-integrated-services-routers/112033-c2900-password-recovery-00.html
Ans; There are multiple options for it. It depends on you that which one will like you. The easiest solution is copying running configuration on ftp or tftp server.
copy running-config ftp:
and flow the all instructions.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi sir & tnx for your nice reply. One more question please. How can I copy a command so that I don't need to re-type it again & paste it?
Yes, copy and paste commands from a document like text or web site into Putty terminal of a Cisco device.
also, to save config, you can copy/paste from Putty into text document works
Regards, ML
**Please Rate All Helpful Responses **
I think I didn't make it clear sir. Suppose I wish to re-type a command. I use "show run" command & wish to copy & paste a command in command line. How can I do it?
As I am understating that you want to make an auto script that You will type only one keyword or command and it will auto-type all other commands related to this. Is it true?
If it is ok then you can make same using the tcl scripting language as:
https://www.ciscozine.com/ios-scripting-with-tcl/
Deepak Kumar,
