Switch
deepak behera
Community Member
Hallo All,
Which Layer-2 Switch support all above advantages as below ?
48 Port Managed Layer-2 Switch with 48 10/100-base T Ethernet Ports, 04  Dual Personality 10/100/1000 base-T Ethernet Ports;
have mandatory Multicasting Support, ie Support for “IGMP Snooping v2” and “IGMP Querier” Protocols.
Ganesh Hariharan
Hallo All,
Hi Deepak,
I am not aware of cisco switches for dual personality support but HP Proc curve switches 2900 and 2500 do support this dual personality support.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
if you need 04  Dual Personality check Catalyst 3750-X and 3560-X Switches,
if you need 2 dual personality check C2960-48TC-L,....
Thanks Sir
Leo Laohoo
Sounds like the 2350 to me.  The two 10Gb ports support X2 twin-gig converters.  So you can use either fibre or copper SFP.
The next contender is the 2960G-48:  It has 44 10/100/1000BaseTx and 4 dual-personality 1Gb SFP or  10/100/1000BaseTx.
Next one is the 2960-48PS.  It has 48 10/100BaseTx with PoE, two 1Gb SFP and two 1Gb 10/100/1000BaseTx.
