System mac address of ASR
huyupqhjqg
How can I find the system/CPU MAC address of a Cisco ASR device? On a Catalyst switch, I can type
show mac address-table | include CPU
to find the system mac, but there's no mac address table on an ASR.
Show interface x/x
This will give you mac of each interfere
8 Replies 8
Try
show bridge-domain
That did not seem to work for me unfortunately, it does not recognize that command. It is an ASR9k if that helps at all.
TotallyTodd
Totally
show version
command may work
TotallyTodd
totally interested to see the output of
show version
on the ASR if you don't mind! totally hope it works!
TotallyTodd
Also,
show version
may totally show you the base Mac address on the switch for the device itself,  as opposed to the interface Mac address totally!
I think there is no mac address for cpu in asr9k or any router.
The cpu mac in l2sw is use as source of some specific control frame like
stp dtp cdp lldp
In l3 device the mac address of interface is used control frame like
 ospf bgp eigrp arp...etc.
Anyway I will make double check this point.
If that's the case, do you know the command to get the mac address of an interface?
Show interface x/x
