System was restarted by bus error at PC 0x623A3CF8, address 0x23 at 10:43:44 UK Thu Nov 4 2010
imediacast2010
our router start restarting itself I believe its bug but I get the error below but did not find anything online for the fix
some people say you need to upgrade IOS
could you please help?
PRODUCT TYPE (Model Number): Cisco 2801
* SOFTWARE VERSION:IOS Version:12.4(4)XC7
* BRIEF PROBLEM DESCRIPTION:
2801 Software (C2801-ADVENTERPRISEK9-M), Version 12.4(4)XC7, RELEASE SOFTWARE (fc1)
Compiled Wed 01-Aug-07 00:56 by alnguyen
Image text-base: 0x6008C860, data-base: 0x63185140
Stack trace from system failure:
FP: 0x661A7C30, RA: 0x623A3CF8
FP: 0x661A7C70, RA: 0x623A415C
FP: 0x661A7C98, RA: 0x623A2BC8
FP: 0x661A7CB0, RA: 0x62375880
FP: 0x661A7D10, RA: 0x6237F4BC
FP: 0x661A7D28, RA: 0x61840694
FP: 0x661A7D80, RA: 0x61841ACC
FP: 0x661A7DA0, RA: 0x61841B88
Bert Gevers
Hello Ozhan,
this reload is caused by the following defect:
CSCsd70772 Externally found moderate (Sev3) bug: Resolved (R)
NBAR: bus error when translating UDP packet
Integrated in  12.4(06)T04 12.4(09)T01 12.4(09.02)T
You can view the details of this defect in our bug tool:
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
Upgrading to any version later than the ones above will fix the issue.
Bert
Peter Paluch
Hello Ozhan,
A bus error generally means that the CPU tried to access a memory location that is not physically accessible. In most cases, this is a problem of the operating system. You are running the 12.4(4)XC7 version which is quite old and in furthermore, it is a special branch of IOS that was created only to implement and test a particular enhancement feature, and this feature was then reintegrated back into the 12.4 or 12.4T train at some time later.
I therefore strongly recommend to upgrade to the newest 12.4 or 12.4T IOS in a particular feature set that fits your memory and FLASH resources, and see whether the problem is resolved.
Best regards,
Peter
Hi Peter
Thanks for quick reply
Do you have any instruction that I can follow to upgrade the IOS ?
regards
Hi Ozhan,
See the next thread you have created - I have answered this question there.
Best regards,
Peter
Bert Gevers
Hello Ozhan,
Bert
