1 router 2 isp
kdurinyan
Hello, I know this question is raised many times, but unfortunately I could not find answer for my case. I have a router (R1) and 2 connections to 2 different ISP. In another location I have 1 router (R2) with 1 connection to 1 ISP. The goal is to make.
1. 2 tunnels between R1 and R2.
R1 - tun1 - ISP1 - Internet - ISP3 - R2
R1 - tun2 - ISP2 - Internet - ISP3 - R3
Note: both tunnels must be Up simultaneously, no SLA, BACKUP, etc... solutions are acceptable.
2. Provide LAN (rfc1912 IP range) behind  R1 Internet connectivity.
Note: ISP1 is primary, ISP2 is backup, here SLA solution is acceptable.
3. From Internet must be possible to connect to VPN server on R1 via both ISPs
What I have tried.
a. SLA works fine for point 2. But point 1 and 3 cannot be solved with SLA
b. ip local route-map and route-map. Works fine for point 2, but no point 1. Did not check point 3 but ping from Internet was OK via both ISP.
c. vrf-lite. works for point 1, but not for point 2. Did not check point 3 but again ping from Internet was OK via both ISP.
The important points are 1 and 2.
Anybody has deal with such setup? Any advise, documentation, comments are appreciated.
Thanks everybody for help and no help:)
P.S.
In ideal case PI IPv4 /24 network + ASN and BGP is the best solution, then I need only 1 tunnel. But small companies like mine cannot afford such things, unfortunately.
7 Replies 7
kdurinyan
To be more specific... network diagram is attached. Configs of CE and R are below for VRF-lite version.
Everything works fine except NAT. I understand I cannot configure interface fa 1/0 on CE to be in 2 of VRFs at the same time. So NAT is not working. How this can be solved?
version 12.4
hostname ce
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 5
ip cef
ip vrf p1e
rd 100:1
ip vrf p2e
rd 200:1
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
  hidekeys
interface Tunnel1
description VPN to R via P1E
ip address 10.214.0.6 255.255.255.248
ip mtu 1416
ip ospf cost 1000
tunnel source FastEthernet0/0
tunnel destination 3.3.3.33
tunnel path-mtu-discovery
tunnel vrf p1e
interface Tunnel2
ip address 10.215.0.6 255.255.255.248
ip mtu 1416
ip ospf cost 2000
tunnel source FastEthernet0/1
tunnel vrf p2e
interface FastEthernet0/0
ip vrf forwarding p1e
ip address 1.1.1.11 255.255.255.0
ip nat enable
speed 100
full-duplex
interface FastEthernet0/1
ip vrf forwarding p2e
ip address 2.2.2.22 255.255.255.0
ip nat enable
speed 100
full-duplex
interface FastEthernet1/0
ip address 10.10.10.1 255.255.255.0
ip nat enable
speed 100
full-duplex
router ospf 1
ispf
log-adjacency-changes
passive-interface default
no passive-interface Tunnel1
no passive-interface Tunnel2
network 10.10.10.1 0.0.0.0 area 0
network 10.214.0.6 0.0.0.0 area 0
network 10.215.0.6 0.0.0.0 area 0
ip forward-protocol nd
ip route vrf p1e 0.0.0.0 0.0.0.0 1.1.1.1
ip route vrf p2e 0.0.0.0 0.0.0.0 2.2.2.1
no ip http server
no ip http secure-server
ip nat source list nat interface FastEthernet0/0 vrf p1e overload
ip nat source list nat interface FastEthernet0/1 vrf p2e overload
ip access-list extended nat
permit ip host 10.10.10.10 any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
version 12.4
hostname r
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
log config
  hidekeys
interface Loopback1
ip address 10.30.0.1 255.255.255.0
interface Tunnel1
description VPN to CE via P1E
ip address 10.214.0.1 255.255.255.248
ip mtu 1416
ip ospf cost 1000
tunnel destination 1.1.1.11
interface Tunnel2
description VPN to CE via P2E
ip address 10.215.0.1 255.255.255.248
ip mtu 1416
ip ospf cost 2000
tunnel destination 2.2.2.22
ip address 3.3.3.33 255.255.255.0
speed 100
full-duplex
no ip address
shutdown
speed 100
full-duplex
router ospf 1
ispf
network 10.30.0.1 0.0.0.0 area 0
network 10.214.0.1 0.0.0.0 area 0
network 10.215.0.1 0.0.0.0 area 0
ip route 0.0.0.0 0.0.0.0 3.3.3.1
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Talking myself?
Managed almost everything to work. Only some problem with dynamic NAT.
It is working when ISP1 (p1e) is Up, but not working when it goes down.
Here is configuration. If anybody knows better way for solution of mentioned problem I would be happy for comments. Thanks.
Bests,
Karen
version 12.4
hostname ce
boot-start-marker
boot-end-marker
logging buffered 4096
no logging console
enable password test
no aaa new-model
memory-size iomem 5
ip cef
ip vrf local
rd 0:0
route-target export 0:0
route-target import 0:0
route-target import 100:1
route-target import 200:1
ip vrf p1e
rd 100:1
route-target export 100:1
ip vrf p2e
rd 200:1
route-target export 200:1
no ip domain lookup
username test password 0 test
archive
log config
  hidekeys
track 1 rtr 1
interface Tunnel1
ip vrf forwarding local
ip mtu 1416
ip ospf cost 1000
tunnel vrf p1e
interface Tunnel2
ip mtu 1416
ip ospf cost 2000
tunnel vrf p2e
ip nat enable
speed 100
full-duplex
ip nat enable
speed 100
full-duplex
ip nat enable
speed 100
full-duplex
router ospf 1 vrf local
ispf
router bgp 65535
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf p2e
  redistribute connected
  redistribute static
  no synchronization
exit-address-family
address-family ipv4 vrf p1e
  redistribute static
  no synchronization
exit-address-family
address-family ipv4 vrf local
  redistribute static
  no synchronization
exit-address-family
ip route vrf local 0.0.0.0 0.0.0.0 1.1.1.1 track 1
ip route vrf local 0.0.0.0 0.0.0.0 2.2.2.1 2
no ip http server
ip nat source list nat-p1e interface FastEthernet0/0 vrf local overload
ip nat source list nat-p2e interface FastEthernet0/1 vrf local overload
ip nat source static tcp 10.10.10.10 23 1.1.1.11 23 vrf local extendable
ip nat source static tcp 10.10.10.10 23 2.2.2.22 23 vrf local extendable
ip access-list extended nat-p1e
ip access-list extended nat-p2e
ip sla 1
icmp-echo 3.3.3.1 source-ip 1.1.1.11
timeout 3000
vrf p1e
frequency 10
ip sla schedule 1 life forever start-time now
control-plane
line con 0
line aux 0
line vty 0 4
login local
line vty 5 15
login local
end
kdurinyan
OK, seems dynamic nat problem is also solved. Don't know if this is acceptable to use route-map with nvi. According docs this is not supported.
Thanks everybody.
Bests,
Karen
version 12.4
hostname ce
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 5
ip cef
ip vrf local
rd 0:0
ip vrf p1e
rd 100:1
ip vrf p2e
rd 200:1
no ip domain lookup
username cco password 0 test
archive
log config
  hidekeys
track 1 rtr 1
interface Tunnel1
ip mtu 1416
ip ospf cost 1000
tunnel vrf p1e
interface Tunnel2
ip mtu 1416
ip ospf cost 2000
tunnel vrf p2e
ip nat enable
speed 100
full-duplex
ip nat enable
speed 100
full-duplex
ip nat enable
speed 100
full-duplex
ispf
router bgp 65535
no synchronization
no auto-summary
  redistribute static
  no synchronization
exit-address-family
  redistribute static
  no synchronization
exit-address-family
  redistribute static
  no synchronization
exit-address-family
no ip http server
ip nat source route-map nat-p1e interface FastEthernet0/0 vrf local overload
ip nat source route-map nat-p2e interface FastEthernet0/1 vrf local overload
ip sla 1
timeout 3000
vrf p1e
frequency 10
route-map nat-p2e permit 10
match ip address nat-p2e
match interface FastEthernet0/1
route-map nat-p1e permit 10
match ip address nat-p1e
match interface FastEthernet0/0
control-plane
line con 0
line aux 0
line vty 0 4
login local
line vty 5 15
login local
end
Karen, congratulations.
P.S.: Sorry about my English.
REALLY creative solution!
I'm on a similar problem right now, and I was forgetting about VRF.
My problems began when our costumer changed his primary ISP.
The previous ISP accepted packets sent with different source IP Address, does not dropping as spoofing.
My solution until that was:
- Tracks SLA to both gateways
- Static Nats based on RouteMap
- Dynamic Nats based on RouteMap
- PBR to a RouteMap with a "set ip next-hop verify-reachability", to stations.
- Default-Routes with tracks and different administrative distances
The things where working well until that
Now with the new primary ISP, that solution isn't working anymore.
The new ISP blocks Spoofing.
What  I'm doing at this moment is almost the same that previous, but with a route to the other router/32 point to ISP2 with a track and a lower  administrative distance.
- Only the side of ISP1 is responding to incoming NAT (here we are using DNS SRV)
- Only the second tunnel is UP(over ISP2)
- When one of the links goes down the services come up on the other side.
But this situation is not really comfortable.
One friend had mentioned to use to default routes.
With that the router would use a "per-flow" based routing.
So if the client comes first from one side, the route cache for that source would be assigned to that ISP link.
I don't trust really much on that, but I'm disposed to try it.
Bottom Line
Is this environment working well now?
What is the IOS Version and router model?
Thanks for congratulations,
I have tested this in GNS3 with real IOS so this must not be problem. Only the issue is dynamic NAT with VRF. I read in documents that route-map is not supported with VRF, but it worked for me during test. So I will be happy if some expert would confirm that this is ok.
HW was Cisco 2691 (in real life I would use Cisco 2800 series, just GNS does not support it so I did test with 2691)
IOS version I have used is c2691-advipservicesk9-mz.124-15.T4.bin
Your solution with 2 default route is ok when we are talking about access to Internet. But how VPN Tunnels will work? Just imagine 1 time it will try to connect to the same destination tunnel with 1st ISP (depends on CEF condition) and other time it may use other ISP. In the end it is possible that router will try to establish 2 tunnels via the same ISP. This was the case for me, I needed to have two tunnel up simultaneously - one via 1st ISP and 2nd via the other ISP.
OK, to make sure I am not doing anything unsupported (route-map with VRF and NVI), I have removed ip nat enabled and back to ip nat inside/outside domains. I can say my all problems mentioned in very first post are solved. I post working configuration here, I hope this can help someone else to solve the similar problem. Thanks and good luck.
used HW: cisco 2691
used IOS: c2691-advipservicesk9-mz.124-15.T4.bin
configuration:
version 12.4
hostname ce
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 5
ip cef
ip vrf local
rd 0:0
ip vrf p1e
rd 100:1
ip vrf p2e
rd 200:1
no ip domain lookup
archive
log config
  hidekeys
track 1 rtr 1
interface Tunnel1
ip mtu 1416
ip ospf cost 1000
tunnel destination 6.6.6.2
tunnel vrf p1e
interface Tunnel2
ip mtu 1416
ip ospf cost 2000
tunnel vrf p2e
ip nat outside
speed 100
full-duplex
ip nat outside
speed 100
full-duplex
ip nat inside
speed 100
full-duplex
ispf
router bgp 65535
bgp router-id 10.10.10.1
no synchronization
no auto-summary
  redistribute static
  no synchronization
exit-address-family
  redistribute static
  no synchronization
exit-address-family
  redistribute static
  no synchronization
exit-address-family
no ip forward-protocol nd
no ip http server
ip nat inside source route-map nat-p1e interface FastEthernet0/0 vrf local overload
ip nat inside source route-map nat-p2e interface FastEthernet0/1 vrf local overload
ip nat inside source static tcp 10.10.10.10 23 1.1.1.11 23 vrf local extendable
ip nat inside source static tcp 10.10.10.10 23 2.2.2.22 23 vrf local extendable
ip sla 1
timeout 3000
vrf p1e
frequency 10
control-plane
line con 0
line aux 0
line vty 0 4
login local
line vty 5 15
login local
end
Karen
By now we decided used the two default routes in our environment, so I couldn't use your solution.
But there is some routers available here, and when a get some time I will make a physical lab.
I will inform you of the results.
Again, congrats for the great solution, and thanks for the help.
