T1 Wan lab setup
Jose Borquez
I am attempting to setup a home practice wan lab with 3 1841 routers.  Routers R1 & R3 each have 1 wic 1dsu t1 v2 interface and R2 has two wic 1dsu t1 v2 interfaces to connect to R1 & R3.  I am experiencing a problem where the serial connection from R2 to R3 has line status of up and protocol status of down.  The serial connection from R2 to R1 is up up.  The configs on each router look good, but perhaps I am missing something.  Are two T1 lines supported on an 1841?  Should I switch the interfaces to wic 1t?  Below are the configs for each router if anyone can identify a configuration problem.  Any help would be greatly appreciated.  Thank you.
R1#sh run
Building configuration...
Current configuration : 815 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description Link to R2
ip address 10.1.1.1 255.255.255.252
encapsulation ppp
no fair-queue
service-module t1 clock source internal
service-module t1 timeslots 1-24
ip classless
ip http server
no ip http secure-server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
_______________________________________________________
R2#sh run
Current configuration : 1005 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
log config
  hidekeys
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
description Link to R1
ip address 10.1.1.2 255.255.255.252
encapsulation ppp
interface Serial0/1/0
description Link to R3
ip address 10.2.2.2 255.255.255.252
encapsulation ppp
ip forward-protocol nd
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
R3#sh run
Current configuration : 865 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
log config
  hidekeys
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address 10.2.2.1 255.255.255.252
encapsulation ppp
no fair-queue
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
Richard Burts
There are several things that might cause these symptoms. I would start by checking on the clocking. I note that R1 to R2 is reported as working and the clock source internal is configured on R1. R3 to R2 is reported as not working and the clock source is configured on R2. Try moving the clock source internal to R3 and see if it makes any difference.
Rick
Rick
