TACACS auth on Mgmt interface
cheeseburger
I'm having a really difficult time getting TACACS working on a new ASR1001x.
I have the device cabled on the management interface and I can ping the TACACS server. Management interface is in the Mgmt-intf VRF. Here is a copy of my config, where am I wrong? I can SSH to the device and use local creds to gain access.
aaa new-model
aaa group server tacacs+ TACACS1
server name DV-ACS-1
aaa authentication login default group TACACS1 local
aaa authorization exec default group TACACS1 local none
aaa authorization commands 15 default group TACACS1 local none
aaa accounting exec default start-stop group TACACS1
aaa accounting commands 15 default start-stop group TACACS1
interface GigabitEthernet0
vrf forwarding Mgmt-intf
ip address 10.206.40.95 255.255.255.0
negotiation auto
tacacs server DV-ACS-1
address ipv4 10.162.0.11
key <key>
timeout 5
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 10.206.40.1
ip tacacs source-interface GigabitEthernet0
line vty 0 4
session-timeout 120
exec-timeout 120 0
transport input ssh
line vty 5 15
exec-timeout 120 0
privilege level 15
transport input ssh
7 Replies 7
Richard Burts
I think that you probably need some like ip vrf forwarding vrf-name   under the tacacs server config.
Rick
Rick
cheeseburger
I found this link and basically copied it exactly and now it seems to be working. I guess I need this server-private ... anyway, maybe someone else will stumble across this post one day and see how to resolve the issue...
http://blog.monkeyrouter.com/2014/04/tacacs-over-management-vrf.html
<--- Enable AAA --->
aaa new-model
<--- Create a AAA TACACS server goup --->
aaa group server tacacs+ [ACS_GROUP]
 server-private [TACACS_SERVER1] timeout 3 key [TACACS_KEY]
 server-private [TACACS_SERVER2] timeout 3 key [TACACS_KEY]
 ip vrf forwarding Mgmt-vrf
 ip tacacs source-interface GigabitEthernet0/0
aaa authentication login default group [ACS_GROUP] local
aaa authentication login console group [ACS_GROUP] local
aaa authorization console
aaa authorization exec default group [ACS_GROUP]
aaa accounting exec default start-stop group [ACS_GROUP]
aaa accounting commands 1 default start-stop group [ACS_GROUP]
aaa accounting commands 15 default start-stop group [ACS_GROUP]
aaa accounting connection default start-stop group [ACS_GROUP]
aaa accounting system default start-stop group [ACS_GROUP]
<--- Send TACACS traffic to the Mgmt interface --->
Thanks for the update. It is good to know that you found a link with a helpful example and that your configuration is now working. And thanks for sharing the link.
Rick
Rick
Thank you so much for posting this!  This worked for my 9800 WLC!!!  TAC couldn't even help me on this!
Extremely appreciative!!!
BlackSharpie
Another THANK YOU for posting this! This resolved my issue as well on 9200 & 9300 switches.
It seems that the monkeyrouter.com blog is now defunct, but the configuration commands above are accurate.
Noora
Reporting in from 2025, and this is still the way.
Also reporting in from 2025. This is the way to go.
<--- Can be configured as a global command. I have not tested under only the aaa group server configuration --->
