TCAM issue in cisco router 7606
Majid Jalinousi
Hi buddies,
It's some days, there is below log in our Cisco 7606 router:
FM-4-TCAM_ENTRY: Hardware TCAM entry capacity exceeded
you can see output of show tcam count in below:
Used Free Percent Used Reserved
Labels:(in) 31 4065 0
Labels:(eg) 3 4093 0
ACL_TCAM
Masks: 3884 212 94 72
Entries: 17091 15677 52 576
QOS_TCAM
Masks: 4 4092 0 18
Entries: 22 32746 0 144
LOU: 39 89 30
ANDOR: 1 15 6
ORAND: 0 16 0
ADJ: 3 2045 0
And as a result some of packets will be dropped. What is the problem and how can we get better experience?
Thanks in advance,
7 Replies 7
Marvin Rhoads
I'm not sure about the answer but I am pretty sure the question has nothing to do with the title or Sourcefire Licenses.
For a useful answer, I suggest you repost in the Network Infrastructure > WAN Switching and Routing forum with a title that matches the question.
Vinit Jain
Could you please share the below command outputs:
- show mls cef summaru
- show mls cef exception status
- show ip route summary
- show tcam - show tcam count - show fm summary - show fm feature
Would like to know did you start seeing the TCAM error after configuring a RACL on VLAN interface? if that is the case, try the following:
rtr(config)# mls aclmerge algorithm odm
rtr(config) mls aclmerge odm optimization
++ Then remove and reapply "access-groups" commands on all the interfaces. This includes all the PBRs as well that is utilizing any ACL and is applied under any interface.
 Please let me know if that helps.
--Vinit
Thanks for your answer,
I think the reason for our problem si assigning RACL, because has not been configured on the router than RACL.
you can see output of you required commands,
would you please share with me what's the reason for this error and dropping the data packets?
sh mls cef summary
Total routes:                     3097
    IPv4 unicast routes:          3093
    IPv4 Multicast routes:        3
    MPLS routes:                  1
    IPv6 unicast routes:          0
    IPv6 multicast routes:        0
    EoM routes:                   0
Current IPv4 FIB exception state = FALSE
Current IPv6 FIB exception state = FALSE
Current MPLS FIB exception state = FALSE
sh ip route summary
IP routing table name is default (0x0)
IP routing table maximum-paths is 32
Route Source    Networks    Subnets     Replicates  Overhead    Memory (bytes)
connected       0           161         0           8552        27692
static          2           22          0           1968        4128
ospf 100        34          1389        0           96764       273216
  Intra-area: 107 Inter-area: 406 External-1: 7 External-2: 898
  NSSA External-1: 0 NSSA External-2: 5
internal        30                                              69720
Total           66          1572        0           107284      374756
sh tcam counts
ACL_TCAM
QOS_TCAM
  Masks:      4        4092            0                    18
    LOU:     39          89           30
  ANDOR:      1          15            6
  ORAND:      0          16            0
    ADJ:      3        2045            0
sh fm summary
Interface: Tunnel128 is up
  TCAM screening for features: ACTIVE inbound
  TCAM screening for features: ACTIVE outbound
Interface: Tunnel132 is up
Interface: Tunnel136 is up
Interface: Tunnel192 is up
Interface: GigabitEthernet1/5 is up
Interface: GigabitEthernet1/6 is up
Interface: POS2/0/0 is up
Interface: POS2/0/1 is up
Interface: GigabitEthernet3/7 is up
Interface: GigabitEthernet3/8 is up
Interface: GigabitEthernet3/16 is up
Interface: GigabitEthernet5/1 is up
Interface: Vlan2 is up
Interface: Vlan5 is up
  TCAM screening for features: INACTIVE inbound
Interface: Vlan8 is up
Interface: Vlan12 is up
Interface: Vlan13 is up
Interface: Vlan14 is up
Interface: Vlan15 is up
Interface: Vlan16 is up
Interface: Vlan17 is up
Interface: Vlan18 is up
Interface: Vlan19 is up
Interface: Vlan20 is up
Interface: Vlan21 is up
Interface: Vlan22 is up
Interface: Vlan23 is up
Interface: Vlan24 is up
Interface: Vlan25 is up
Interface: Vlan26 is up
Interface: Vlan27 is up
Interface: Vlan28 is up
Interface: Vlan29 is up
Interface: Vlan30 is up
Interface: Vlan31 is up
Interface: Vlan32 is up
Interface: Vlan34 is up
Interface: Vlan35 is up
Interface: Vlan36 is up
Interface: Vlan37 is up
Interface: Vlan38 is up
Interface: Vlan39 is up
Interface: Vlan42 is up
Interface: Vlan43 is up
Interface: Vlan46 is up
Interface: Vlan47 is up
Interface: Vlan48 is up
Interface: Vlan49 is up
Interface: Vlan50 is up
Interface: Vlan51 is up
Interface: Vlan60 is up
Interface: Vlan62 is up
Interface: Vlan64 is up
Interface: Vlan65 is up
Interface: Vlan66 is up
Interface: Vlan81 is up
Interface: Vlan82 is up
Interface: Vlan100 is up
Interface: Vlan101 is up
Interface: Vlan102 is up
Interface: Vlan103 is up
Interface: Vlan104 is up
Interface: Vlan105 is up
Interface: Vlan106 is up
Interface: Vlan107 is up
Interface: Vlan108 is up
Interface: Vlan109 is up
Interface: Vlan110 is up
Interface: Vlan111 is up
Interface: Vlan112 is up
Interface: Vlan113 is up
Interface: Vlan114 is up
Interface: Vlan115 is up
Interface: Vlan116 is up
Interface: Vlan117 is up
Interface: Vlan119 is up
Interface: Vlan120 is up
Interface: Vlan130 is up
Interface: Vlan192 is up
Interface: Vlan200 is up
Interface: Vlan201 is up
Interface: Vlan202 is up
Interface: Vlan203 is up
Interface: Vlan204 is up
Interface: Vlan224 is up
Interface: Vlan225 is up
Interface: Vlan226 is up
Interface: Vlan252 is up
Interface: Vlan253 is up
Interface: Vlan255 is up
Interface: Vlan2390 is up
Show fm features brief
Interface: Vlan52 IP is enabled
  hw_state[INGRESS] = not reduced, hw_state[EGRESS] = not reduced
  mcast = 0
  priority = 0
  flags = 0x0
  parent[INGRESS] = none
  inbound label: 168
    Feature IPV4 Default Result Feature:
    Feature OTHER Default Result Feature:
Interface: Vlan60 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan61 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 168
Interface: Vlan62 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan64 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 130
    Feature IP_ACCESS_INGRESS:
        ACL: CP
Interface: Vlan65 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 130
        ACL: CP
Interface: Vlan66 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan81 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 136
        ACL: 181
Interface: Vlan82 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan100 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 137
        ACL: 100
Interface: Vlan101 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 138
        ACL: 2101
Interface: Vlan102 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 139
        ACL: 2102
Interface: Vlan103 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 140
        ACL: 103
Interface: Vlan104 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 141
        ACL: 104
Interface: Vlan105 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 142
        ACL: 105
Interface: Vlan106 IP is enabled
  hw_state[INGRESS] = globally reduced, hw_state[EGRESS] = not reduced
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 143
        ACL: 106
Interface: Vlan107 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 144
        ACL: 107
Interface: Vlan108 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 145
        ACL: 108
Interface: Vlan109 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 146
        ACL: 109
Interface: Vlan110 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 147
        ACL: 110
Interface: Vlan111 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 148
        ACL: 111
Interface: Vlan112 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 149
        ACL: 112
Interface: Vlan113 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 150
        ACL: 113
Interface: Vlan114 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 151
        ACL: 114
Interface: Vlan115 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 152
        ACL: 2115
Interface: Vlan116 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 153
        ACL: 116
Interface: Vlan117 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 154
        ACL: 117
Interface: Vlan119 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan120 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan124 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 168
Interface: Vlan130 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan192 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan200 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan201 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan202 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan203 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan204 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan205 IP is disabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 134
Interface: Vlan224 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan225 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan226 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 157
        ACL: Allow-List
Interface: Vlan252 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan253 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan255 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
Interface: Vlan2390 IP is enabled
  mcast = 0
  priority = 0
  flags = 0x0
  inbound label: 119
On which SVI was the RACL configured? Also, could you please paste the complete syslog message. There should be 2 entries, one showing the TCAM error and other entry which shows the VLAN id where the RACL was configured.
--Vinit
Almost on all Vlan that the RACL configured I can see this error, like vlan120, or Vlan14.
 %FM-4-TCAM_ENTRY: Hardware TCAM entry capacity exceeded
Nov 26 12:50:46.264: %FMCORE-4-RACL_REDUCED: Interface Vlan14 routed traffic will be software switched in ingress direction
 %FMCORE-4-RACL_REDUCED: Interface Vlan120 routed traffic will be software switched in ingress direction
One surprising thing was when I removed the RACL under VlanX, there is no difference in the output of show tcam command. shouldn't it has released the TCAM entry after removing the RACL?
Finally would you please tell me about a solution? And I would be so appreciate to know about mechanisms for TCAM entry assignment in the cisco 7606 router.
Thanks.
The error message indicate that the TCAM resources being used by the ACL's are too large and the packets will be process switched rather than being hardware switched. There are two ACL-merge algorithms available to optimize the TCAM resource utilization for ACL's - the binary decision diagram (BDD) and the order dependent merge (ODM). ODM is the enhanced algorithm.
The first step of the Action Plan to try to reduce the TCAM usage would be:
CONFIGURE ODM algorithm instead of BDD
o mls aclmerge algorithm odm
o mls aclmerge odm optimizations <<< This command is hidden
Any acls that are already applied will not re-merge unless you do one of the following:
1) Remove the acls from the interfaces and reapply them,
2) Shut/no-shut the interfaces,
3) Reload the router.
The second step would be:
To apply this feature, you need to enable the following command:
o mls acl tcam share-global
Please follow the above steps and let me know the results.
Hope this helps.
--Vinit
Hi Vinita,
Thanks for your comment,
I did whatever you recommended, but there is no effect on the state of TCAM table.
Actually I even remove the the ACL from device, but the show TCAM counts showed the same number as before.
I want to know how can I do for releasing the TCAM table?
