TCP retransmission with Port mirroring
bartj
I am using some SG200-08 Cisco switches on a local network with some custom hardware I am debugging. I have setup one of the switches to mirror rx/tx traffic so that I can sniff packets with wireshark on a PC that is not part of the network. However, I find that the traffic as captured by wireshark on the PC that is accepting the mirrored packets duplicates every packet as a "TCP Retransmission".
I have attached 2 files, one showing the duplicate packets (Wireshark_dups.PNG) and another taken with wireshark on the host PC which is part of the network(Wireshark_no_dups.PNG). The later file contains no duplicate packets. Note that the 2 files are not time correlated, they serve only as examples of the packet duplication issue.
I have tried disabling spanning tree options but that makes no difference.
Does anyone have any suggestions as to how to get rid of: "TCP Retransmission" packets?
bartj
5 Replies 5
dmuinoorallo
There are different causes for this, typical issues are disconnect ethernet cable or congestion in this interface.
I need more information about your shema of network for help you
I have attached a PNG showing the current network configuration. I have changed it a bit from the last post so that I only see traffic to/from the HOST PC and the custom hardware. TCP re-transmission is still an issue. Any insights appreciated.
bartj
In a TCP/IP Client-Server Model arch, TCP retransmission can happen ONLY when the transmitting end does not recieve TCP-ACK from the receiving end.
 Few possibilites of NOT receving TCP-ACK are,
  • The receiving end sent back TCP-ACK is LOST in transit.
  • The transmitting end TCP-DATA is LOST and it did not reach the receving end at all.
Check for error along the traffic path, problems in layer 1 and layer 2.
dmuinoorallo,
Thank you for your comments. Its interesting that there are TCP re-transmissions for both directions of traffic (HOST > Custom HW and Custom HW to HOST).
I will attempt to do more testing on Tuesday when I have access to the hardware.
Thanks again!
We have the same problem with retransmission. How did you solve the problem?
Did you figure out the cause of retransmission?
Thank you for your help,
Dan
