TCP-RST
Buka Jorbenadze
Hello
I have a Check-Point virtual firewall in the network, connected to  router, with a 0.0.0.0 route pointing towards the router. When the Check-Point needs to update, it  traffic through the router, which performs NAT to an external IP.
Now, the issue is as follows: I captured traffic on the router and observed returned packets with RST. The source is 1.1.11.1 and the destination IPs are shown in the screenshot. Additionally, at certain moments, updates are partially downloaded—some files are retrieved, but then the connection stops and resets.
I suspect the issue might be related to the router. This capture  take from   router's interface.
I am also sharing the command executed from the Check Point server, which failed to complete successfully.
thanks
10 Replies 10
TCP-RST can cause of Asymmetric you point the traffic toward the router but the retrun traffic is still come toward FW
MHM
Where would the asymmetry occur? The outgoing and incoming  interfaces on the firewall are the same
you redirect traffic to router, am I correct ?
Yes, I am sending  update traffic from the Check Point, and it goes to the router, then  returned traffic enters the router and goes to the Check Point and this  capture i took it from the router.
tcp.flags.reset == 1 <<- use this to filter and disaply only rest packet
then add new column TTL let see which TTL appear for above filter packet
MHM
win=0
the client buffer is full that why no ACK and packet need to re transmit
check bug and windows scale op in both clinet and server
MHM
@Buka Jorbenadze
 It does not make sense. The command you ran on CheckPoint is trying to connect on port 80. You had one success and one fail attempt.
 The log you collected from router is HTTPS traffic, port 443.  For me, it is not the same traffic.
who have the IP address 1.1.11.1 ?
I think this traffic is difference not for update Server, The checkpoint IP address is 1.1.11.1
If the CheckPoint have the IP address 1.1.11.1 then the check point sent the reset when the IP address on the internet tried to communicate on port 443 with CP.
Make sure you have rule allowing this traffic coming from the internet.
