Telnet using source IP address
snarayanaraju
Level 7
Level 7
Dear Experts,
Is there any way I can TELNET using the source IP address. I am aware of the
command
telnet 192.168.1.1 /source-interface fastethernet 0
But Here in this command I am able to specify only the Interface and not the
IP Address. Why i raised this point is, I am trying to TELNET a remote host
using my secondary IP address of the Interface.
Thanks in advance
sairam
somsh
Community Member
hi mate,
It is possible , try this command 🙂
telnet 10.10.10.1 /source-interface fastEthernet 0/1 /route:(Ip )
Cheers
Som
5 Replies 5
Richard Burts
sairam
I am not aware of any way in IOS to telnet and to source the telnet packets from a secondary address. When an IOS router generates a packet (including generating a telnet packet) the default is to use the primary address as the source and I am not aware of any way to change this behavior.
Rick
Rick
Hi Rick,
Thanks. recently i surfed a Blog site and got the workaround for source telnet. But he didnt said how to do.He has shown only the solution. Please refer the link below
http://blog.zakir.net/index.php?/archives/44-Router-Tricks-Sourcing-telnet-from-secondary-IP-address.html
Hope it will give some clues. Please suggest how it works
sairam
Had anybody seen the link. can you please shed some light on this
sairam
somsh
Community Member
hi mate,
Cheers
Som
Have you gone thru the link. I am not able to understand or interpret the way he made the ACL to do Source TELNET
Thanks in advance
sairam
