Terminating VPN into MPLS
tahscolony
I am trying to design a way to use one router to terminate VPN connections, and for security reasons, keep traffic separate.  So one internal interface is in vrf trusted, where I want to terminate a host of VPNs, and the other interface is in vrf untrusted, where I want to terminate other VPN's. The Public side would not be in a vrf.
Is this possible, and is there an example of what the VPN configuration would look like? It would be standard L2L IPSec VPN.   I already have the vrf configured with separate routing tables BGP and OSPF.
5 Replies 5
Philip D'Ath
I like to use ISAKMP profiles for this.
crypto keyring kr-dsto
  pre-shared-key address ...
crypto isakmp profile isakmp-client1
  vrf client1
  keyring kr-client1
  match identify address ...
  local-address ...
crypto map-cryptomap 113 ipsec-isakmp
  set isakmp-profile isakmp-client1
tahscolony
Actually its IPSec encrypted GRE tunnels.  So if I create a tunnel interface in a vrf, and source the external non-vrf interface IP, will it work?
Are we talking about modern VTI tunnels, that use the "tunnel protection" command?
Just normal GRE over IPSec.
interface Tunnel64
 ip vrf forwarding Inside
 ip address 169.254.169.254 255.255.255.254
 tunnel source 1.2.3.4
tunnel destination 4.3.2.1
Tunnel source is the outside interface of the router which is not associated with any vrf.
Yes, I believe that would work.
