Testing out frame relay connections
rdrusty54
Hello all. Just had a quick question. I'm looking to test fram relay connections in a lab environment i'm building at home. I have a couple of 2610 routers that are barebones and am looking to get some serial modules. Are (2) WIC-2T's all I would need to create those test connections? Also on a side note are the any modules for the 2610 that have fast ethernet connections. I would like to have that so I can create a router on a stick model off of the 2600's.
Thanks guys
lucentmoon
Towards the bottom it shows the compatible expansion cards.  Wic-2Ts look fine.  No capability for extra fast eth ports.
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd800fa5be.html
