tftp server
mailaglady2
Level 5
Level 5
I want to load an ios on a 7613 router and 6509 switch, these ios's are on my pc. has someone done this before and which tftp server software did you use, do you have a detailed step by step procedure? your assistance would be greatly appreciated. before I forget the image size is 128MB
2 Accepted Solutions
Wilson Samuel
Level 11
Level 11
There is a Freeware I use, Pumpkin TFTP Server. Fairly stable and can really take good amt of load.
You may locate it here
http://www.softpedia.com/get/Internet/Servers/Other-Servers/PumpKIN.shtml
Or
Bing (MSFT Fan) it and you should be able to locate a downloadble file.
Please rate all helpful posts
Wilson Samuel
Mpho
You will need access to the Internet for your PC to download the TFTP server software. After you have downloaded the software to your PC then you need to install the software.
After you have installed the TFTP server software you need to connect your PC on a LAN which connects to your router and switch. Your PC needs to have an IP address which establishes IP connectivity between your PC and your router and switch. Then you run the TFTP software on your PC. The details of how to point the TFTP software to the directory/folder where the image file is located may vary depending on which software you are running for TFTP.
Then on the router and on the switch you need to copy the image file from TFTP to the disk. The syntax may vary a bit depending on the model of equipment but is something like:
copy tftp: flash:
then the copy process will prompt for a couple of things including the address of the TFTP server and the name of the image file to copy. Then the copy process will copy the image file from your PC to your router or switch.
Rick
Rick
5 Replies 5
Wilson Samuel
Level 11
Level 11
Or
Wilson Samuel
Richard Burts
Mpho
The tftp server which many of us use, and which can handle image sizes as big as you mention, is tftpd32. This link will allow you to get started with it.
http://tftpd32.jounin.net/tftpd32_download.html
Since you specifically ask about TFTP I have given a TFTP answer. I will also point out that the data transfer with FTP is quicker and more efficient than TFTP. With an image of 128 MB you might want to think about using FTP rather than TFTP.
Rick
Rick
jim_berlow
Level 6
Level 6
Since no one else mentioned it...
I personally hate to wait that long for a 128 MB size file to transit through TFTP. If you have a compact flash (or there is one inside the supervisor), I would simply copy it on to that and then over to the equipment. This will save you quite a bit of time.
HTH,
Jim
Thanks for these quick responses, my router is not configured to access the internet. How do I setup this tftp/ftp server on my local machine for my boxes(router and switch) to download these ios from my PC. Never done this before
Mpho
copy tftp: flash:
Rick
Rick
