the cisco's router 2800 series hangs when start up
spabloulises
the prompt show this:
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c2801 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
open(): Open Error = -13
loadprog: error - on file open
boot: cannot load "flash:c2801-entbasek9-mz.151-4.M8.bin"
PLD version 0x10
program load complete, entry point: 0x8000f000, size: 0x22c3cb0
Self decompressing the image : ################################################################################################################################################################################################################# [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X00020000 Crypto module pools
0X002D 0X00000000 UNKNOWN Card in slot 0
0X0002 0X0001A800 Card in slot 1
0X002D 0X00000000 UNKNOWN Card in slot 2
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 15861013 bytes to IO Memory.
PMem allocated: 243269632 bytes; IOMem allocated: 25165824 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 2801 Software (C2801-ENTBASEK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:41 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2801 (revision 7.0) with 237568K/24576K bytes of memory.
Processor board ID FTX1253Y0JC
2 FastEthernet interfaces
1 Serial(sync/async) interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
123136K bytes of ATA CompactFlash (Read/Write)
Warning: MD5 encryption will be deprecated soon.Please move to SHA256 encryption.
SETUP: new interface NVI0 placed in "shutdown" state
Press RETURN to get started!
*Dec 12 23:26:53.771: %CFG-3-CARD_NOT_SUPPORTED: Slot 0: DID Voice daughter Card (2 port), Part# 80-6487-5, HW-Rev 1.0, Board-Rev C0, S/N 36757409
*Dec 12 23:26:53.851: %CFG-3-CARD_NOT_SUPPORTED: Slot 2: DID Voice daughter Card (2 port), Part# 80-6487-5, HW-Rev 1.0, Board-Rev C0, S/N 36087640
*Dec 12 23:27:01.207: %LINK-3-UPDOWN: Interface Serial0/1/0, changed state to down
*Dec 12 23:27:02.207: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0, changed state to down
*Dec 12 23:27:05.119: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Dec 12 23:27:05.119: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Dec 12 23:27:18.783: %SYS-5-CONFIG_I: Configured from memory by console
*Dec 12 23:27:19.311: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to down
*Dec 12 23:27:19.727: %SYS-5-RESTART: System restarted --
*Dec 12 23:27:19.751: %SNMP-5-COLDSTART: SNMP agent on host HORIZONTES is undergoing a cold start
*Dec 12 23:27:20.263: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*Dec 12 23:27:20.503: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*Dec 12 23:27:20.619: %LINK-5-CHANGED: Interface Serial0/1/0, changed state to administratively down
*Dec 12 23:27:20.787: %LINK-5-CHANGED: Interface NVI0, changed state to administratively down
Leo Laohoo
Remove the NM and WIC from these slots and try again.
