The problem with "service-policy input" and "ip nat outside" on same interface
villi1977
Hello All.
I have a problem.
service-policy input Sawary isn't working for fake ip addreses.
It's working for 77.87.16.98 but it's not working for network 10.12.0.0.
We using "ip nat outside" rules on same interface where we using "service-policy input Sawary".
Any ideas please please please.
You can see example:
class-map match-all Sawary
match access-group name Sawary
policy-map Sawary
class Sawary
    police 2048000 256000 512000 conform-action transmit  exceed-action drop  violate-action drop
interface GigabitEthernet0/0.100
ip nat outside
service-policy output Sawary
ip access-list extended Sawary
permit ip any host 10.12.0.9
permit ip host 10.12.0.9 any
permit ip any host 10.12.0.5
permit ip host 10.12.0.5 any
permit ip any host 10.12.0.7
permit ip host 10.12.0.7 any
permit ip any host 10.12.0.11
permit ip host 10.12.0.11 any
permit ip any host 10.12.0.12
permit ip host 10.12.0.12 any
permit ip any host 10.12.0.6
permit ip host 10.12.0.6 any
permit ip any host 10.12.0.3
permit ip host 10.12.0.3 any
permit ip any host 10.12.0.4
permit ip host 10.12.0.4 any
permit ip any host 10.12.0.15
permit ip host 10.12.0.15 any
permit ip any host 10.12.0.16
permit ip host 10.12.0.16 any
permit ip any host 77.87.16.98
permit ip host 77.87.16.98 any
Giuseppe Larosa
Hello Villi1977,
please add the NAT configuration, where network 10.12.0.0 is supposed to be ? on the internal LAN?
additional info is needed to get help
Hope to help
Giuseppe
You can see nat:
encapsulation dot1Q 100
ip address 77.87.16.3 255.255.255.224
ip broadcast-address 0.0.0.0
ip flow ingress
ip flow egress
ip nat outside
no ip virtual-reassembly
ip nat pool 1 77.87.16.3 77.87.16.3 netmask 255.255.255.224
ip nat inside source list 110 pool 1 overload
access-list 110 remark DSL-data-customers
access-list 110 permit ip host 10.12.0.9 any
access-list 110 permit ip host 10.12.0.5 any
access-list 110 permit ip host 10.12.0.7 any
access-list 110 permit ip host 10.12.0.11 any
access-list 110 permit ip host 10.12.0.12 any
access-list 110 permit ip host 10.12.0.6 any
access-list 110 permit ip host 10.12.0.3 any
access-list 110 permit ip host 10.12.0.4 any
access-list 110 permit ip host 10.12.0.15 any
access-list 110 permit ip host 10.12.0.16 any
access-list 110 permit ip host 10.12.0.17 any
interface Virtual-Template1
ip unnumbered Loopback0
ip nat inside
peer default ip address pool l2tp
ppp authentication pap
ppp multilink
This nat working from "interface Virtual-Template1" to "interface GigabitEthernet0/0.100"
The interface Virtual-Template1 i done for  l2tp connections.
Hello Villi1977,
from the point of view of NAT outside interface gi0/0/.100 NAT translation is already performed so ip addresses of type 10.12.0.X are not seen on it.
You should put in the named ACL Sawary used for QoS the  outside ip address
77.87.16.3 instead of the inside private addresses.
It is a question of order of operations: translation of source ip address of packets is performed before QoS on outside interface examines them.
Hope to help
Giuseppe
Thank you.
