The strange trouble with C2950T
stitov
Hello all.
I have a trouble with WS-C2950T-24(121-19.EA1c). Sometimes, I see the log message:
: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/4, changed state to upSCHAN ERROR INTR: unit=0 SRC=6 DST=5
OPCODE=20 ERRCODE=5
OPCODE=20 ERRCODE=5
OPCODE=20 ERRCODE=5
after that I dont see the mac-address table from this device. What means this message?
you could be hitting the following bug:
CSCdv83336 Bug Details
Under certain level of traffic load, the switch will start logging the
following messages on the console:
SCHAN ERROR INTR: SRC=6 DST=5 OPCODE=20 ERRCODE=5
and after a few seconds, the switch will stop passing any traffic. In some
cases, the switch seemed still forwarding broadcast and multicast traffic,
which will cause STP problem if the switch has redundant link and is not
supposed to be the root for the VLAN, as both port will go forwarding.
The same error message has been identified in CSCdu87836.
An assessment of the impact
Unit stops passing any traffic.
WORKAROUND
Several units were returned by CISCO. The units were re-screened to the
latest test program, and failed the SDRAM memory test.
Customer should RMA unit back to Cisco.
HTH,
GP
