the understand of ping sweep option.
syjeon
I wonder if there is a default incremental value in ping sweep option.
Please attention as following:
6pe01.kcn.ia#ping vrf wonchul
Protocol [ip]:
Target IP address: 169.254.100.98
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]: y
Sweep min size [36]: 1460
Sweep max size [18024]: 1600
Sweep interval [1]:
Sending 705, [1460..1600]-byte ICMP Echos to 169.254.100.98, timeout is 2 seconds:
regarding result of above log, the ping was dropped on specific ping payload
segment.
first of all, I know the specific value when ping dropped when I ran ping sweep.
and then I would like to know sweep interval
Is there a default ping sweep incremental value?
Giuseppe Larosa
Hello Sung,
Sweep interval [1]:
this sweep interval is actually the step increment see the following:
ping
Protocol [ip]:
Target IP address: 10.99.72.1
Repeat count [5]: 1
Sweep min size [36]: 1450
Sweep max size [18024]: 1520
Sweep interval [1]: 4
Sending 18, [1450..1520]-byte ICMP Echos to 10.99.72.1, timeout is 2 seconds:
Success rate is 100 percent (18/18), round-trip min/avg/max = 12/15/20 ms
if I change to 1
ping
Protocol [ip]:
Repeat count [5]: 1
Sweep interval [1]:
Sending 71, [1450..1520]-byte ICMP Echos to 10.99.72.1, timeout is 2 seconds:
Success rate is 100 percent (71/71), round-trip min/avg/max = 12/15/20 ms
notice that number of packets for a given size is still specified by Repeat count
Hope to help
Giuseppe
You could also use the verbose option, which will actually tell you the largest packet that gets through.
