Throttle HTTP traffic
jarmentrout
I am trying to throttle all http traffic to a fixed rate (512K) and can't seem to make it work
rate-limit input access-group 101 512000 512000 512000 conform-action transmit exceed-action drop
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any eq www any
also tried puting both input and output
I have two interfaces, S0/0 connected to T1, and E0/0 connected to PIX and rest of LAN
After making changes, do a bandwidth test and I am still receiving full t1 at 1.5megs. When using all available bandwidth it saturates the line and causes latency to go way high. I would like to throttle HTTP and FTP traffic to give a little breathing room for other types of traffic.
I am using a 3640 router.
Mark Turpin
Level 5
Level 5
On your T1 interface you are probably looking for something like this:
interface Serial0/0
ip address a.b.c.d 255.255.255.252
rate-limit input 512000 8196 8196 conform transmit exceed drop
That will police the inbound traffic (assuming that you're pulling content). If you're the one serving the content, reverse that to be an output in your rate-limit command.
Those 2nd and 3rd values are burst normal and burst max byte values, not bps values, so you don't need 512k, an 8k burst value is plenty.
Also, make sure you write your ACL with direction in mind. If you're pulling content (you have users surfing the web) then you want to write your ACL like this:
access-list 101 permit tcp any eq 80 any
access-list 101 permit tcp any eq 443 any
You won't need to change your ACL if you're the one serving the content - just change the rate-limit command.
-Mark
-Mark Turpin
Made the changes on burst size and HTTP is working now. I am also trying to limit FTP traffic, but it seems that it uses random ports, so it will be difficult to identify this traffic. I trying using ftp and ftp-data protocol. Any other suggestions.
