MAC address restriction on 2950-24T
anand
i have got 2950-24T, i wanted to restrict only MAC address to use the fas 0/1 port, if some other MAC address NIC is connected it should not allow is it possible? i tried the following options but couldn't suceed.
interface fas 0/1
switchport mode access
switchport port-security
switchport port-security maximum 6
switchport port-security aging static
switchport port-security mac-address sticky
switchport port-security mac-address sticky 0000.0000.000b
amit-singh
Level 8
Level 8
Hi Anand,
First of all please check the number of sticky addresses in the port security table of the switch. The max number of addresses allowed on the interface is 6 so it should learn the 6 mac-addresses and then it will deny the next one.
Use command " show port security "
Please define the voilation mode to shutdown also.
Also check the output of the command " show port-security interface fastethernet0/1 ".
it should show it as enabled and active.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950scg/swtrafc.htm
HTH,
-amit singh
