Time Zones and Best Practices
Scott Hanson
Level 3
Level 3
All,
If I have several sites across the country but the HQ is on EST what is the recommended practice to configure the time zones on the network equipment in different time zones.  Should it be configured to match the local time zone or the time zone of the HQ?  In this case the HQ is where all the management of the network equipment is performed.  I can see an argument for both ways
Thanks in advance!  All replies rated.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I suggest using UCT.
As I read the original post it seems the question is whether to have the time zone of network equipment reflect the local environment or whether they should all be set with a common value. I believe that the response from Joseph indicates a common setting and further advocates not setting a time zone but using the default Universal Coordinated Time.
Before I give a response I believe that there are a couple of questions we should look at before we make a decision. In particular we need to understand whether there are any things in the configuration that are time sensitive, such as time based access list, or perhaps EEM scripts that might trigger based on time. In that case matching the local environment is preferable.
I note that the original post tells us that all management of the network devices is done from HQ. I believe that this is an important qualification and in this case I agree with Joseph that setting to a common time zone is preferable. It could be especially helpful in situations where you are investigating an issue and are comparing logs from multiple devices in multiple time zones to have a common version of what time the event occurred. That is also a point that emphasizes the importance of using NTP to set the time.
Rick
Rick
Leo Laohoo
Depends on who's doing the monitoring.
If you're using EST at HQ and you've got routers on the PST zone, why bother doing two (or more) timezones.  Settle to a timezone where it's easy to determine the exact time of the event and no need to convert.
The main thing is to ensure the appliance's clock source is set accurately.  Make sure the logging event has the correct time/date/year setting.
I have seen a lot of "sh logs" where network admin were just too "irresponsible" to realize how important the second and third lines of any configurations are.
