12-08-2010 12:42 AM - edited 03-04-2019 10:43 AM
I have taken a public ip pool from isp 116.214.x.x/29 . i need to open axis bank site through isa server
i am not able to open from ip 116.214.x.x but if i put any other ip from same pool in isa i am bale to open.
can any body give detail description where can be problem it is public dns issue or ISA or public ip or between some internetwork
Rajat
12-08-2010 01:44 AM
can anybody reply ?
12-08-2010 08:59 AM
Its hard say.
Are you using the public IP's configured on a LAN segment, or just for NAT?
If you use them on a LAN segment the first and last ip will be net id and broadcast. Then youd need 1 for default gateway which would leave 5 to use instead of 8.
Also are you peering with the ISP on another subnet or using this /29 for that as well?
12-08-2010 08:13 PM
we are not peering with any other customer pool with isp but we are using NAT can u recommend something can be done at ISA end or something in the DNS
waiting for reply
Rajat
12-10-2010 05:06 AM
can any body reply ?
12-10-2010 05:10 AM
I can reply.
But since i can't understand how your setup looks, or exactly what the proplem is I have no advice to give.
I can only guess that the IP not working for you is in use somewhere.
12-10-2010 05:16 AM
you are coorect wr are not able to open site by using one of the public ip taken from Tulip
while using any Ip from same pool we are able to open with proxy and without pro
xy and it is Axisbank site and using port no. 80. kindly recommend
