Traceroute Issue
Hello All
If we are working in any organization and we do
traceroute
So how can we identify that this Hop IP is belong to which device .
I am doing
getIP -ip
but not getting any details .
Please provide your suggestions .
Hi @Rajvendra pratap singh
Trace route
do name resolution if the path is on the internet. If you are using
traceroute
internally,  it may show only the IP address.
 What you can do is try to access the IP you see and get the  hostname or, if those IP are registered on the
dns
you can
ping -a
The command you mention you are running on Windows machine with power shell?
5 Replies 5
Trace route
traceroute
dns
you can
ping -a
Hi @Flavio Miranda
Thankyou for your response .
The command i mentioned i am running on windows machine .
dns
you can
ping -a
on windows machine or power shell for example
ping -a IP
dns
The answer from your explain'
The router IP must add to DNS to make
tracroute show hostname not IP
I will share lab may be help you in
dns traceroute
it not depend on Internet or local, it depend on DNS,
here three router I config ip host name IP in IOU1
and then use traceroute and you can see the result is traceroute show hostname not IP
hope this help you in your task
thanks
MHM
