Traceroute not working in One Dierection
grew00028
My trace is not working in one direction.
Ping for Site A to Site B and vice versa works (PING's are from CE TO CE and CPE)
SITEA#ping vrf DDDDD-DDDD x.x.228.57 source x.x.228.65
Sending 5, 100-byte ICMP Echos to x.x.228.57, timeout is 2 seconds:
Packet sent with a source address of x.x.228.65
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/8 ms
SITEA#ping vrf DDDDD-DDDD x.x.228.58 source x.x.228.65
Sending 5, 100-byte ICMP Echos to x.x.228.58, timeout is 2 seconds:
SITEB#ping vrf DDDDD-DDDD x.x.228.65 source x.x.228.57
Sending 5, 100-byte ICMP Echos to x.x.228.65, timeout is 2 seconds:
Packet sent with a source address of x.x.228.57
Success rate is 100 percent (5/5), round-trip min/avg/max = 7/7/8 ms
SITEB#ping vrf DDDDD-DDDD x.x.228.66 source x.x.228.57
Sending 5, 100-byte ICMP Echos to x.x.228.66, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 6/6/7 ms
Trace works from SITE A to SITE B (FROM CE to CE and CPE)
SITEA#trace vrf DDDDD-DDDD x.x..228.57 source x.x.228.65
Tracing the route to 172.25.228.57
VRF info: (vrf in name/id, vrf out name/id)
1 x.x.54.198 4 msec 0 msec 0 msec
2 x.x.43.150 4 msec 4 msec 4 msec
3 x.x.43.149 8 msec * 8 msec
SITEA#trace vrf DDDDD-DDDD x.x..228.58 source x.x.228.65
Tracing the route to 172.25.228.58
3 x.x.43.149 8 msec 8 msec 8 msec
4 x.x.228.58 8 msec * 8 msec
Trace from SITEB to SITEA only works till CE interface (.228.65) but does work for CPE (.228.66)
SITEB#trace vrf DDDDD-DDDD x.x.228.65 source x.x.228.57
Tracing the route to x.x.228.65
1 x.x.43.150 3 msec 3 msec 2 msec
2 x.x.54.198 6 msec 7 msec 6 msec
3 x.x.54.197 7 msec * 7 msec
SITEB#trace vrf DDDDD-DDDD x.x.228.66 source x.x.228.57
Tracing the route to x.x.228.66
1 x.x.43.150 3 msec 3 msec 3 msec
2 x.x.54.198 5 msec 6 msec 6 msec
3 x.x.54.197 7 msec 7 msec 7 msec
4 * * *
5 * * *
(edited OUTPUT)
29 * * *
30 * * *
Harold Ritter
Ping works from x.x.228.57 to x.x.228.66, but traceroute from x.x.228.57 to x.x.228.66 don't. So it looks like routing is fine.
ping uses ICMP and traceroute uses UDP, so It could be due to an ACL on Site A CPE that does not allow UDP traffic in or out.
I double checked all the CE's and CPE's. There are no ACL's for UDP.
