track num rtr missing
pronin_sergey
Hello guys,
I have a switch WS-C3560G-48TS.
The version of IOS is:
WS-C3560G-48TS     12.2(58)SE2           C3560-IPSERVICESK9-M
The command "track number rtr" is missing. There are just three options there:
#track 10 ?
  interface  Select an interface to track
  ip         IP protocol
  list       Group objects in a list
Why is that so and where is rtr?
I have the same switch with the following ios version:
WS-C3560G-24TS     12.2(50)SE1           C3560-IPSERVICESK9-M
rtr is present in there.
Peter Paluch
Hi Sergey,
This command is most probably replaced with the track number ip sla command, as the CLI has changed quite considerably regarding the RTR functionality (it is called IP SLA now). Try that out.
Best regards,
Peter
Peter Paluch
Hi Sergey,
Best regards,
Peter
Hi Peter,
you are right. Thank you Cheers.
