track reachability unsupported
Vinayaka Raman
Hello friends, Do you know why show track is listing as unsupported in the attached e-mail.
I was trying to test it out and it didn't work.
Regards Vinayak
Vinayaka Raman
I am running it on Cisco router for HSRP
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.4(9)T7, REL
EASE SOFTWARE (fc3)
CR1#show ip route 10.200.1.1
Routing entry for 10.200.1.1/32
  Known via "bgp 65457", distance 20, metric 0
  Tag 65000, type external
  Last update from 68.136.158.157 17:38:20 ago
  Routing Descriptor Blocks:
  * 68.136.158.157, from 68.136.158.157, 17:38:20 ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag 65000
CR1#show ip route 10.200.1.2
Routing entry for 10.200.1.2/32
  Last update from 68.136.158.157 17:38:41 ago
  * 68.136.158.157, from 68.136.158.157, 17:38:41 ago
      AS Hops 2
      Route tag 65000
Regards Vinayak
i have upgrade the IOS to higher version and the issue is resolved..I can see track is learning the route from bgp...thanks
Regards Vinayak
