Tracking Features
cineca
Level 2
Level 2
Is PBR with Tracking options feature available on all the IOS-feature Set of 12.3(4)T ? Or should I install a specific IOS-feature set ?
Thanks to all will answer ..
A.Asson
spremkumar
Level 11
Level 11
As per this link the support is available since 12.2(T) ios code itself..but later some enhancements like some new commands been added in the the later ios trains..
would suggest you to check this link out ..
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1839/products_feature_guide09186a00801541be.html
regds
Georg Pauwen
according to the Feature Navigator, the PBR with Multiple Tracking Options feature is available for all IOS feature sets, starting with IP Only. However, I get about 20000 results for all platforms and feature sets - do you have a specific platform you want to run this on ?
GP
Yes, a couple of 2811 routers.
Thank You.
A.Asson
