11-05-2009 09:51 AM - edited 03-04-2019 06:37 AM
Hi, we have two internet connections at a remote site. The primary connection is a full T1 and DSL as a backup.
Is there a way to manage the router traffic to designate the DSL backup to handle all HTTP traffic and designate the T1 for all other traffic?
I ask because the DSL connection has a larger downstream speed.
Thank you,
Andrew
Solved! Go to Solution.
11-05-2009 08:42 PM
Andrew,
You will need to cofigure policy base routing on the 1760, you can have something as this.
route-map http-https_traffic_Via_DSL permit 10
description web outbound traffic_Via DSL
match ip address 101
set ip next-hop
access-list 101 permit tcp any any eq 80
access-list 101 permit tcp any any eq 443
Apply route map to router FEthernet interface
interface
ip policy route-map http-https_traffic_Via_DSL
any www and https traffic request coming from your LAN will go out via DSL link, none web traffic ftp rdp etc..will go regular default route via T1.
Hope this helps
11-05-2009 08:42 PM
Andrew,
set ip next-hop
interface
Hope this helps
11-07-2009 06:21 AM
Andrew, are you all set with your request or still need help?
11-09-2009 08:03 AM
Thank you Jorge! That was really helpful
