03-08-2018 05:26 PM - edited 03-05-2019 10:03 AM
Hi, I'm trying to shape traffic on my network for a QoS project. I need to set an average and peak shape.
The issue I'm running into is that I can only set the average shape? I am shaping from within a class in a policy map.
This is from Packet Tracer but the problem also persists on the 2911 routers at my university. any help would be great !
Matt
Solved! Go to Solution.
03-09-2018 10:33 AM
I tested out some releases, 15.2(4)S supports the 'shape peak' command, it looks like you need an S or T release.
Don't worry about what is available or not in Packet Tracer, as it uses just a very limited subset of the commands of a 'real' IOS.
03-09-2018 04:25 AM
'shape peak' is not supported on all platforms. Can you post the output of 'show version' of one of your 2911 routers ?
03-09-2018 06:38 AM
R1#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thurs 5-Jan-12 15:41 by pt_team
ROM: System Bootstrap, Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
cisco2911 uptime is 1 minutes, 37 seconds
System image file is "flash0:c2900-universalk9-mz.SPA.151-1.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FTX152400KS
3 Gigabit Ethernet interfaces
2 Low-speed serial(sync/async) network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249856K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2911/K9 FTX15245305
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security disable None None
uc disable None None
data disable None None
03-09-2018 10:33 AM
03-16-2018 07:36 AM
