Traffic shaping per client on ISR 4331
Hi all
We have a 100Mbps Internet link, feeded by 4 proxy nodes. The proxies are accessed by around 800 users. The point is now I only have four IP addresses as the sources which pass the router. But as every single user creates one or more sessions, I have around 14'000 sessions which pass the router.
My idea now is to shape the traffic, so that if one user starts a download of let's say 10GB, that after a certain amount of traffic downloaded via one single session, the traffic will be throttled to let's say 1Mbps, so that not one or two users can use the whole bandwidth.
Does someone has a config for an ISR4000 router, who had a similar issue and who successfully implemented such as a restriction for the download traffic?
Thanks a lot
Markus
Joseph W. Doherty
I'm unaware of a feature to support that on an ISR 4K.
Off the top-of-my-head, the only technology that comes close is something like a 6500's microflow policer.
Joseph W. Doherty
Thanks Joseph for your input. Let's see if other tech guys also supports your statement. The other idea I had was to put another device in front of the ISR 4k which handles this functionality.
Yea, again though, you might find slim picking for such a feature.
The only other devices that might offer something like that would be something designed for the digital DSL or cable users.
Another problem you might run into is being on the outside of your proxies might hide the aggregate bandwidth of all "user" sessions, although you might still be able to target flows.
