Traffic Shaping with acl
drojasug33
I'm thinking about applying differente traffic shaping to packets with different destination in the same interface. So the idea is to identify the traffic in the inbound interface, and then if the packet destination is X then he gets 5Mbps but if the packet destination is Y then he gets 10 Mbps.I've tried with acls, but I figured that you can't assign two different acls to the same intreface. I cant use subinterfaces.
Thanks in advance.
Daniel
Giuseppe Larosa
Hello Daniel,
first of all shaping can only be done outbound on outgoing interface
you need to use QoS, modular QoS, and you can define different traffic classes and in defining those traffic classes you use different ACLs
access-list 111 permit ip host x  host y
access-list 112 permit ip host x host z
class CM-1
match access-group 111
class CM-2
match access-group 112
policy-map shape_multiple
class CM-1
shape average 5000000
class CM-2
shape average 10000000
int wan
service-policy output shape_multiple
you can define more classes as needed
Hope to help
Giuseppe
Giuseppe Larosa
Hello Daniel,
class CM-1
class CM-2
class CM-1
class CM-2
int wan
Hope to help
Giuseppe
Thanks a lot for your help.
I'm going to try it.
Daniel
Hi giuslar,
I have another question. Do I have to apply the acl on the interface?
Thanks.
Daniel Rojas
drojasug33 wrote:
Hi giuslar,
Thanks.
Daniel Rojas
Daniel
No you don't. ACL's can be used for a number of different things eg. route-maps, NAT, QOS and none of these need the acl to be applied to the interface. Just apply the service-policy and you will be fine.
Jon
