09-16-2019 09:48 PM
good day. ISR 4351/K9 IOS 16.09.04 i need to make "ip nat inside source static" for range 5100-5200 tcp ports. i have find code, like next:
ip access-list extended 190
permit tcp host 192.168.0.10 range 5100 5200 any
route-map MAP_RST permit 10
match ip address 190
ip nat inside source static 192.168.0.10 92.50.234.196 route-map MAP_RST extendable
It works, but it doesn't limit translation to another ports.That is, like this code:
ip nat inside source static 192.168.0.10 92.50.234.196 extendable
How to make limitations?
Solved! Go to Solution.
09-17-2019 12:55 AM
try the below (I made some assumptions for your inside and outside interfaces, so the IP addresses, masks, and interfaces you actually use might be different):
interface GigabitEthernet0/1
desccription LAN
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0
description WAN
ip address 92.50.234.196 255.255.255.248
ip nat outside
ip nat pool POOL 192.168.0.10 192.168.0.10 netmask 255.255.255.0 type rotary
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside destination list TCP_RANGE pool POOL
access-list 1 permit 192.168.0.0
ip access-list extended TCP_RANGE
permit tcp any any range 5100 5200
09-17-2019 01:48 AM
Hello
Try adding an additional route-map statement to deny all other traffic .
route-map MAP_RST deny 99
09-17-2019 12:14 AM
is 92.50.234.196 the IP address of the NAT outside interface (e.g. GigabitEthernet0/0)? If so, try the below:
ip nat inside source list 190 interface GigabitEthernet0/0 overload
09-17-2019 12:41 AM
thanks, added this code:
ip nat pool RST1-pool 92.50.234.196 92.50.234.196 netmask 255.255.255.248
ip nat inside source list 190 pool RST1-pool overload
but ports are still available, for example 80,443 from outside
09-17-2019 12:55 AM
desccription LAN
ip nat inside
description WAN
ip nat outside
09-17-2019 01:03 AM
I can not assign x.x.x.196 a primary address. Primary is other address.
09-17-2019 01:35 AM
do you need to translate to the x.x.x.196 address, or can you use the address assigned to your outside interface ?
09-17-2019 06:28 PM
Many thanks to Paul and Georg for the right advices. I solved the problem in a slightly different way: I found a way on the software to reduce the port range from 100 to 10, and registered the usual static translations. Not very beautiful, but very simple and effective.
09-17-2019 01:48 AM
Hello
