Triple ISP with Cisco IOS XR
Marc du
Hi Cisco Experts
Greeting
I lost my way with RPL config , calling all of you to help  me  how the RPL config  looks like for the below scenario , 2 X  ASR 9006
0utbound policy
1. AS 52X accepts local routes from the 3 providors , along with default for the rest of the internet routes
2. Traffic destined to ISP-1 goes via ASR-1
3. Traffic destined to ISP-2 goes via ASR-1
4. Traffic destined to ISP-3 goes via ASR-2
5. all other traffic prefer ASR-1 ISP-1
6. if link to ISP-1 goes down traffic should re-route it via ASR-1 ISP-2
7. if link to ISP-2 goes down traffic should re-route it via ASR-2 ISP-3
Inbound policy
1. Traffic is destinet to PI Subnet 91.X.X.X/24 from Internet shoud come Via ASR-1 ISP-1
2. Traffic is destinet to PI Subnet 92.X.X.X/24 from Internet shoud come Via ASR-1 ISP-2
3. Traffic is destinet to PI Subnet 93.X.X.X/24 from Internet shoud come Via ASR-2 ISP-3
4. if one ISP or Link Fails , other ISP should route traffic back to AS 52X from internet
Thanks all
Sayed hasan moubarak
22 Replies 22
Hi Alexander
thanks for ur reply
here you go for inbound policy result
RP/0/0/CPU0:XR-1#   sh bgp 0.0.0.0/0
Mon Jun 20 23:16:22.089 UTC
BGP routing table entry for 0.0.0.0/0
Versions:
  Process           bRIB/RIB  SendTblVer
  Speaker                 13          13
Last Modified: Jun 20 23:16:01.243 for 00:00:21
Paths: (2 available, best #1)
  Advertised to peers (in unique update groups):
    192.168.21.2
  Path #1: Received by speaker 0
    192.168.21.2
  300
    192.168.31.3 from 192.168.31.3 (30.30.30.30)
      Origin IGP, localpref 250, valid, external, best, group-best, multipath
      Received Path ID 0, Local Path ID 1, version 13
      Origin-AS validity: not-found
  Path #2: Received by speaker 0
  Not advertised to any peer
  500
    192.168.51.2 from 192.168.51.2 (50.50.50.50)
      Origin IGP, localpref 250, valid, external, multipath
      Received Path ID 0, Local Path ID 0, version 0
RP/0/0/CPU0:XR-1#
Bro , what does  bgp bestpath as-path ignore and  bgp bestpath as-path multipath-relax , in my situation as my 1st link to ISP1 its 1GB while the link to ISP2 its 512
bro so for as-path prepending the value should be different for each prefix per ISP
91.x.x.x came via ISP1
92.x.x.x came via ISP2
93.x.x.x came via ISP3
if i  didn't use IP SLA , what would be the issue ?
thanks a lot
that looks good now! multipath is enabled and both default routes will be used on a per flow bases. and if there is good distribution this will be near 50%.
if you want to take the bw into consideration and ratio it 2:1 you need to use dmz link bandwidth to help BGP understand the bandwidth of each link so instead of 50/50 we do 66/33. You can read here how to set up dmz link bw.
rule 5 of BGP best path selection is the as-path. the shorter path will win.
in many cases for loadbalancing over multipath, the different available paths have different lengths of the AS path showing a shorter AS hop count towards the destination. With the as-path ignore we can omit looking at the AS-PATH as a tie breaker for a preferred route.
the AS relax would override the stnadard rule for mpath that both AS-paths should match from all routes. this is also a silly rule, since like in your case you have different ISP's, and they will have different as-path sets and or lengts, each of those knobs will override either of these two rules for as-path consideration.
xander
Hi Alexander
thanks for ur reply
1 ) How to verify " bgp bestpath as-path ignore " and "bgp bestpath as-path multipath-relax" are working ?
2)if i  didn't use IP SLA , what would be the issue ?
thanks a lot
1) if you do a show bgp <prefix>/<mask> and you see that the as-paths are different and the multipath indicator is not set, you knoww what the issue is :)
2) the ipsla helps with the conditional advertisement based on SP availability.
you don'tneed it, per-se, it is a nice to have.
cheers!!
xander
Hi Alexander
thanks for ur reply
1 )for DMZ link bandwidth how the RPL config looks like
ASR-1 Link to ISP-1 Bandwidth 1 GB
ASR-1 Link to ISP-2 Bandwidth 512 MB
both ISP1 and ISP2 connected to ASR-1 while ISP3 connected to ASR-2
2) "How to verify " bgp bestpath as-path ignore " if its working or not
Thanks a lot
Hi Alexander
Bro can you please answer the above Question
thanks
for q1, follow this guide
for q2, the only way to verify that is that if you have a prefix that has 2 paths for which the weight and local pref are the same, then AS-PATH is the next selection criteria. If you then see a path that is chosen that happens to have a longer as-path then you the as-path override kicked in. there is no indicator in show bgp that spells it out, so it comes down to manually evaluating 2 paths, and determine by running the best path algorithm manually what the selection would be.
Noting that in order the selection is: weight, local-pref, as-path, origin, med, e over i, igp next hop metric, oldest, routerID.
xander
Thanks bro Alexander for your good Help
