Trouble with Launching Packet Tracer
shaukatmulla
I am unable to launch Packet Tracer after downloading it from the academy On launch there is a Pop-up window that suggests that the app is unable to associate my net academy credentials and the tracer login. The result is that on closing this popup, I receive an error "login failed" see attached. Have tried to uninstall and reinstall but no joy. Any ideas?
shaukatmulla
The problem has been solved. The two labels on top of the links are actually live and need to be clicked. That creates the association between the academy and packet tracer. It would have helped if it was denoted as such. I found it only by accident.
6 Replies 6
 All you have to do is create a login/password on Cisco network Academy and login in. If you already have, try to reset you credential.
https://www.netacad.com/portal/learning
It doesn't solve the problem in my case. It requested I login on netacad or skill for all which I did successfully, but there was no redirection to open packet tracer
shaukatmulla
I see. Instead of clicking on the links, click on the netacad or skill for all 'labels'.
aahmwasfi
Cisco should make running the Packet Tracer much easier with this hassel that happens every time. Even after logging-in to Networking Academy, the pkt won’t start easily!
dunnojustin77
Packet Tracer Version 8.22.0400 Skillforall button on right
CMD prompt / powershell as admin
netstat -aof | findstr :8001
taskkill /F /PID 6608
( finds and kills PID of taskstring found) Window launches after in Chrome for sign in. Regular email login recommended. Google SSO only lets create acc in country China for some reason.
