Trouble with VLAN ACL and ASA
Dear Sir/Madam
                     I have a issue where i am trying to filter incoming traffic on a VLAN using ACL which is fine However i also have to filter the web site that user on this VLAN can access now I Have an ASA with all the network traffic filtered, however the traffic from the ASA is not getting through the ACL on the vlan I am Sure this is a simple fix for this I just cant seem to put my finger on it
Many thank
Richard Burts
I find the post a bit confusing and lacks detail to allow us to understand the situation. You tell us that you have applied a vlan ACL which is working fine. You also indicate that you are doing some web site filtering on ASA and seem to imply that this is working ok. Then you say that traffic from ASA is not getting through the ACL but do not provide any details about the ACL. At a minimum we need the configuration of the interface and of the ACL and some details about traffic from ASA that does not get through the ACL.
Rick
Rick
I have a vlan that is only allowed to access certain web site the vlan can only have ssh traffic from 2 other networks
