Troubles Adding Switches to a Stack
offodilec
I inherited a switch stack consisting two Cisco WS-C3750X-48T-S switches to which I'm trying to add two more switches of the same make and model (also I downgraded these two newer switches to an older image version so all four switches match). However my attempts to join these two new switches to the stack has failed. The current switch stack does not see the new switches. I ensured my StackWise cabling was correct by following the documentation linked below but still no success.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#stack3
The two new switches are not seen by our current stack, and oddly enough these new switches formed their own stack so now I have two seperate stacks instead of one. An attempt had been made earlier by another tech but the images weren't the same between the older and newer switches, so I wondering if this initial failed attempt may be preventing the switches from joining the stack. An troubleshooting ideas are definitely welcomed.s
5 Replies 5
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I recall (?) you can bump into problems if the switch you intend to add has a configuration that conflicts with existing stack members.  On the to be added switch(s), erase the startup config and see if you can add it.
JohnTylerPearce
Level 7
Level 7
Obunna,
I agree with Joseph, to erase the startup-config, even thought it should technically work.
How is the current stack configured? All they all using the default priority of 1?
Leo Laohoo
Power down the new switches, attach console cable, power up the switches.
I want to see the entire bootup sequence.
Leo,
I try that and will have to boot sequence for you next week. I had to leave due to the snow storm out here.
Here's the boot sequence for the new switch
Switch>en
Switch#wr mem
Building configuration...
[OK]
Switch#reload
Proceed with reload? [confirm]
*Mar  1 00:20:35.524: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload command.
Using driver version 3 for media type 2
Base ethernet MAC Address: 3c:08:f6:0c:04:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 10 files, 1 directories
mifs[2]: Total bytes     :    2097152
mifs[2]: Bytes used      :     612352
mifs[2]: Bytes available :    1484800
mifs[2]: mifs fsck took 1 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes     :    4194304
mifs[3]: Bytes used      :       1024
mifs[3]: Bytes available :    4193280
mifs[3]: mifs fsck took 2 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes     :     524288
mifs[4]: Bytes used      :       9216
mifs[4]: Bytes available :     515072
mifs[4]: mifs fsck took 1 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes     :     524288
mifs[5]: Bytes used      :       9216
mifs[5]: Bytes available :     515072
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 504 files, 12 directories
mifs[6]: Total bytes     :   57671680
mifs[6]: Bytes used      :   22911488
mifs[6]: Bytes available :   34760192
mifs[6]: mifs fsck took 24 seconds.
...done Initializing Flash.
done.
Loading "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:23 by prod_rel_team
Initializing flashfs...
mifs[3]: 10 files, 1 directories
mifs[3]: Total bytes     : 2097152
mifs[3]: Bytes used      : 612352
mifs[3]: Bytes available : 1484800
mifs[3]: mifs fsck took 1 seconds.
mifs[3]: Initialization complete.
mifs[4]: 0 files, 1 directories
mifs[4]: Total bytes     : 4194304
mifs[4]: Bytes used      : 1024
mifs[4]: Bytes available : 4193280
mifs[4]: mifs fsck took 0 seconds.
mifs[4]: Initialization complete.
mifs[5]: Initialization complete.
mifs[6]: 5 files, 1 directories
mifs[6]: Total bytes     : 524288
mifs[6]: Bytes used      : 9216
mifs[6]: Bytes available : 515072
mifs[6]: mifs fsck took 0 seconds.
mifs[6]: Initialization complete.
mifs[7]: 504 files, 12 directories
mifs[7]: Total bytes     : 57671680
mifs[7]: Bytes used      : 22911488
mifs[7]: Bytes available : 34760192
mifs[7]: mifs fsck took 0 seconds.
mifs[7]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: SF ASIC BIST : Begin
POST: SF ASIC BIST : End, Status Passed
POST: Switch Fabric Memory Tests : Begin
POST: Switch Fabric Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
extracting front_end/front_end_ucode_info (309 bytes)
SM: Detected stack cables at PORT2
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750X-48 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1747H2VE
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 3C:08:F6:0C:04:80
Motherboard assembly number     : 73-12552-10
Motherboard serial number       : FDO17472JCY
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3750X-48T-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO17472C3H
System serial number            : FDO1747H2VE
Top Assembly Part Number        : 800-31326-08
Top Assembly Revision Number    : D0
Version ID                      : V05
CLEI Code Number                : COMJT00ARE
Hardware Board Revision Number  : 0x05
3780976K bytes of USB Flash usbflash0 (Read/Write)
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48       12.2(58)SE2           C3750E-UNIVERSALK9-M
Press RETURN to get started!
*Mar  1 00:00:05.024: Read env variable - LICENSE_BOOT_LEVEL =
*Mar  1 00:00:07.147: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3750x Next reboot level = ipbase and License = ipbase
*Mar  1 00:01:03.921: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Mar  1 00:01:06.404: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:01:06.404: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to downAuth Manager registration failed
*Mar  1 00:01:08.887: %USBFLASH-5-CHANGE: usbflash0 has been inserted!
*Mar  1 00:01:09.801: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar  1 00:01:12.293: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 1 inserted
*Mar  1 00:01:12.829: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:01:13.081: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Mar  1 00:01:13.081: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar  1 00:01:13.081: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Mar  1 00:01:14.021: %SYS-5-RESTART: System restarted --
*Mar  1 00:01:14.029: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Mar  1 00:01:15.698: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
*Mar  1 00:01:16.705: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar  1 00:01:17.678: %USB_CONSOLE-6-MEDIA_USB: Console media-type is USB.% Generating 1024 bit RSA keys, keys will be non-exportable...
[OK] (elapsed time was 4 seconds)
*Mar  1 00:01:33.230: %SSH-5-ENABLED: SSH 1.99 has been enabled[OK]
*Mar  1 00:01:33.532: %PKI-6-AUTOSAVE: Running configuration saved to NVRAM
Switch>en
Switch#show switch
Switch/Stack Mac Address : 3c08.f60c.0480
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 3c08.f60c.0480     1      1       Ready
