Troubleshooting pfr configuration
eandrcisco007
I have recently configured PfR on our routers (Two routers) one as a MC and BR with 200 mbps internet connection directly conenctioned to MPLS and the other as a BR with 100 mbps internet connection directly connected to MPLS and change the aggrigation type to BGP and mode route is set to be on observe with below configuration,
The main purpose here by deploying PfR is to use PfR magic to have a redundent path/connection so if traffic on the 1st router hit the 75% of BW utilization treshhold,  the rest of the traffic (25%) would get re-routed to the 2nd router (100 mbps ).
I have been monitoring it for last few days but it doesnt seem to be working fine becaouse the trfaic on the primary router hitting almost 95 percent of its BW and nothing is being re-routed to the backup router!
All configuration looks to be fine and the connection status is success on both MC and BRs...
I am currently using PfR v. 3.3 on primary router and v.3.0 on back up router.
We are redistributing bgp to eigrp and eigrp to bgp using route-maps.
I wonder if anyone could provide some feedback so that i could fix and troubleshoot this issue and make it work.
BR configuration on the backup router :
sh run | s pfr
logging
local Loopback0
master xx.xx.xx.xx key-chain *******
sh pfr border
oer BR xx.xx.xx.xx ACTIVE,  MC xx.xx.xx.xx UP/DOWN: UP 19:00:44
Auth Failures : 0
Conn Status : SUCCESS
OER Netflow Status : ENABLED, PORT : 3949
Version: 3.0   MC Version: 3.3
Exits
Gi 0/0      INTERNAL
Gi0/1       EXTERNAL
MC cofiguration on the primary router :
sh run | s pfr
pfr master
max-range-utilization percent 10
logging
border xx.xx.xx.xx key-chain *****
interface gi 0/1 external
interafce gi 0/0 internal
interafce gi 0/3 internal
learn
inside bgp
aggregation-type bgp
backoff 90 90
mode route observe
pfr border
local Loopback0
master xx.xx.xx.xx key-chain******
sh pfr master
OER State: ENABLES and ACTIVE
Version: 3.3
Number of Border routers : 2
Number of Exits : 2
Number of monitored prerfixes : 210 (max 5000)
Max Prefixes : total 5000 learn 2500
Prefix count : total 210, learn 210, cfg 0
PBR Requirements not met
Nbar staus : Inactive
Auto Tunnel Mode : On
Global Settings:
max-range-utilization percent 10 recv 0
rsvp post-dial-delay 0 signaling-retries 1
mode route metric bgp local-pref 5000
mode route metric static tag 5000
trace probe delay 1000
logging
exit holddown time 60 secs, time remaining 0
Default Policy Settings:
backoff 90 90 90
delay relative 50
holddown 90
periodic 0
prob frequency 56
number of jitter probe packets 100
mode route observe
mode monitor both
loss relative 10
jitter threshhold 20
mos threshhold 3.60 percent 30
unreachable relative 50
trigger-log percentage 30
Learn Settings :
current state : STARTED
time remaining in current state : 70 seconds
throughput
no delay
inside bgp
monitor-period 1
periodic-interval 0
prefixes 100 appls 100
expire after time 720
Please let me know if you need additional details so that i can provide.
Thank you all.
eandrcisco007
Gentelmen,
Any help/comments please?
FYI> It learns all the traffic and prefixes and border router is now running the probes but when i run sh pfr border routes bgp the outcome is none...!!
Sh pfr master statitistics exit shows no activity on one of the border routers and it only shows activities on BR that is in MC router,
I can provide you more details if it would help,
The 2nd boder router doesnt have a direct conenction to master controler but the seeion has established per sh pfr master and sh pfr border.
Any feedback please?
