ASR 1001 ISSU Upgrade Confusion
dan.letkeman
Level 4
Level 4
Ok, so I have dual sup's as seen in the show redundancy command:
1001-1#show redundancy
Redundant System Information :
       Available system uptime = 8 hours, 53 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Duplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 6
        Current Software state = ACTIVE
       Uptime in current state = 8 hours, 52 minutes
                 Image Version = Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.3(2)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 25-Mar-13 15:39 by mcpre
                          BOOT = ,1;bootflash:asr1001-universalk9.03.09.01.S.153-2.S1.bin,1;
                   CONFIG_FILE =
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 7
        Current Software state = STANDBY HOT
       Uptime in current state = 8 hours, 51 minutes
                   CONFIG_FILE =
But there is no standby-bootflash:
1001-1#dir ?
/all             List all files
  /recursive       List files recursively
  all-filesystems  List files on all filesystems
  bootflash:       Directory or file name
  cns:             Directory or file name
  null:            Directory or file name
  nvram:           Directory or file name
  revrcsf:         Directory or file name
  stby-nvram:      Directory or file name
  stby-rcsf:       Directory or file name
  system:          Directory or file name
  tar:             Directory or file name
  tmpsys:          Directory or file name
So I changed the boot comamnd to:
boot system flash bootflash:asr1001-universalk9.03.09.01.S.153-2.S1.bin
and reloaded, but it still doesn't load the correct version.
IOS XE Version: 03.09.00.S
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
hbni-core-asr1001-1 uptime is 9 hours, 1 minute
Uptime for this control processor is 9 hours, 3 minutes
System returned to ROM by reload at 08:45:03 CDT Mon Aug 19 2013
System restarted at 08:48:03 CDT Mon Aug 19 2013
System image file is "bootflash:/asr1001-universalk9.03.09.00.S.153-2.S.bin"
Last reload reason: Reload Command
What am I doing wrong?
Dan.
dan.letkeman
Level 4
Level 4
Figured out the boot system flash problem.
I had a boot system flash command before the boot system flash bootflash:/asr...
So it was loading the default ios from the flash first.
Still dont' know why there is no standby flash though..
I realize this question was asked a long time ago, but the ASR1001 does not have hardware redundancy. The ASR1006 for example has two physical RPs and each has their own DRAM, flash, CPU, etc. The ASR1001 uses software redundancy. So there is one Linux kernel running on one physical CPU. On top of this rides the IOSd process. The redundancy on the ASR1001 is two such IOSd processes and they both share the underlying hardware.
