troubleshooting these E1s
Ibrahim Jamil
Level 7
Level 7
Hi Experts
i have some branches connected over E1s Lines , now they are working properly,later on how to troubleshooting these E1s
thanks
jamil
5 Replies 5
John Blakley
Jamil,
Like Paolo stated, there's really nothing to troubleshoot unless you're having an issue...which we all hope you never have
John
HTH, John *** Please rate all useful posts ***
Guys , but the encap is PPP
If the circuit is up though, there's no need to troubleshoot anything if there aren't any problems. If you're just wanting to see if there are errors, you can do a "sh int " and look for frame or crc errors. If you have any errors like that, then clear counters and watch them over time. If they continue to increment, then you could have a problem with a cable to the demarc or a problem with the circuit itself.
HTH,
John
Thanks John
Encapsulation.doesn't matter. If it works before but not after, is telco fault.
Also, do not low rate posts that are 100% correct just because they don't suit you. That will only make so that professionals on this forum will know how to deal with your questions in the future.
To partially compensate, I've rated it again.
