Trying to do 3-way redistribution between RIP, OSPF, and EIGRP on the same router - Is this possible to confiure?
David Anderson
In the above topology I've configured fairly successfully Redistribution of routing protocols into other protocols domains using route-tagging via route-maps.
- (R1-R5) EIGRP AS 100 can see all OSPF, RIP, and EIGRP AS 200 routes
- (R1 - R2 - R3) OSPF Area 0 can see RIP routes, and routes from both EIGRP AS 100 and AS 200
- (R3 - R4) is able to see EIGRP AS 100 and OSPF routes, but I cannot for the life of me get it to see RIP routes
All I had to do was get RIP and OSPF redistributing, and R5's EIGRP AS 100 got routes no problem and with no further configuration than the OSPF to EIGRP 2-way Redistribution up that way, but for some reason R4 did not get any RIP routes from the OSPF domain, so I set up route-tags and a route-map and Redistributed into each other and still nothing.
I even got so desperate as to try configuring a permit match tag 120 (RIP's tag #) on the OSPF to EIGRP (AS 200) config on R3 and still nothing.
So here is R3's show run, showing the route-maps in place, the RIP2OSPF and OSPF2RIP working fine to get RIP routes up to R5's EIGRP AS:
R3(config-router)#do sh run
Building configuration...
Current configuration : 2647 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
enable secret 5 $1$R0ce$N83Bj3UeiHYf9ctvAxitE.
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
key chain CCNP
 key 1
  key-string CISCO
controller T1 0/0
 framing sf
 linecode ami
controller T1 0/1
 framing sf
 linecode ami
interface Loopback3
 ip address 3.3.3.3 255.255.255.255
interface Loopback33
 ip address 33.33.33.3 255.255.255.0
interface FastEthernet0/0
 ip address 172.12.23.3 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 172.12.34.3 255.255.255.0
 ip authentication mode eigrp 200 md5
 ip authentication key-chain eigrp 200 CCNP
 duplex auto
 speed auto
interface Serial0/2
 ip address 172.12.123.3 255.255.255.0
 encapsulation frame-relay
 ip ospf authentication message-digest
 ip ospf message-digest-key 1 md5 CCNP
 ip ospf priority 0
 frame-relay map ip 172.12.123.2 321
 frame-relay map ip 172.12.123.1 321 broadcast
 no frame-relay inverse-arp
 frame-relay lmi-type cisco
interface Serial0/3
 no ip address
 shutdown
router eigrp 200
 redistribute ospf 1 route-map OSPF2EIGRP
 redistribute rip route-map RIP2EIGRP
 network 172.12.34.0 0.0.0.255
 default-metric 1544 10 255 1 1500
 no auto-summary
router ospf 1
 log-adjacency-changes
 redistribute eigrp 200 subnets route-map EIGRP2OSPF
 redistribute rip metric 2 subnets route-map RIP2OSPF
 network 3.3.3.3 0.0.0.0 area 0
 network 172.12.123.0 0.0.0.255 area 0
router rip
 version 2
 redistribute eigrp 200 metric 2 route-map EIGRP2RIP
 redistribute ospf 1 metric 2 route-map OSPF2RIP
 network 33.0.0.0
 network 172.12.0.0
 no auto-summary
ip http server
no ip http secure-server
route-map EIGRP2RIP deny 10
 match tag 120
route-map EIGRP2RIP permit 20
 set tag 200
route-map RIP2EIGRP deny 10
 set tag 200
route-map RIP2EIGRP permit 20
 set tag 120
route-map EIGRP2OSPF deny 5
 match tag 110
route-map EIGRP2OSPF permit 10
 set tag 200
route-map OSPF2EIGRP deny 10
 match tag 200
route-map OSPF2EIGRP permit 20
 set tag 110
route-map OSPF2RIP deny 5
 match tag 120
route-map OSPF2RIP permit 10
 set tag 110
route-map RIP2OSPF deny 10
 match tag 110
route-map RIP2OSPF permit 20
 set tag 120
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 password CCNP
 logging synchronous
 login
end
R3(config-router)#
I have been searching around to see if what I am doing is beyond the limitation of IOS software, please let me know if there is a mis-configuration or if it's just not possible, as I don't want to spin my tires on something that is not fixable - Any more info requested please let me know.
Thanks for any input!!
Julio E. Moisa
Is possible to have the configuration of each router on text file to lab it? The problem is with R4, right? it is not receiving any RIP routes from R3, these RIP subnets should be known through Eigrp 200.
Also could you please share the routing table of R3.
Just a question, why are you making double set tag when RIP is being distributed into Eigrp 200
 set tag 200    <---- should it be match instead set?
 set tag 120
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
Julio E. Moisa
 set tag 120
Good catch, I don't think that is what is preventing it from propagating, but I will fix that and post R3's route table.
Thank you David. Please keep me posted.
Just changing that to be correctly configured as "match / set" for route tagging on the route-map did the trick, that's what I get for studying until I am falling asleep.
Thanks so much for the catch :) +5 rating for you!
You are welcome  :-)
Thank you so much, have a great day!
