BFD Timer expired
I'm getting below logs on ASR1001-X and my connectivity is flapping on a WAN interface.
 %BFDFSM-6-BFD_SESS_DOWN: BFD-SYSLOG: BFD session ld:1 handle:1,is going Down Reason: DETECT TIMER EXPIRED
Is this a BUG? if so, any upgrade to overcome?
Thanks!
Julio E. Moisa
It could be, do you have bfd configured under interfaces related to a routing protocol?
Something like that? Probably you need to adjust the timers.
interface Fa0/2
ip ospf bfd
bfd interval 250 min_rx 250 multiplier 3
end
router ospf 1
bfd all-interfaces
Also please check this link:
https://quickview.cloudapps.cisco.com/quickview/bug/CSCux51223
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes. BFD configured under interfaces.
I recommend first to verify if your IOS has fixed this issue otherwise it could be upgrade.
