01-16-2015 01:21 PM - edited 03-05-2019 12:35 AM
I have a Cisco 871w which I am using as my router for internet access. It is connected to my cable modem. My outside local interface is Fast Ethernet 4. While my inside interfaces are Fast Ethernet 0 - 3. The subnet for that is 192.168.1.0 255.255.255.0. My wifi subnet is 192.168.2.0 255.255.255.0.
My goal is to have 1 subnet instead of 2. I am not sure how to approach this without bringing down my internet.
Any help would be appreciated!
Here is my config:
R1#show run
Building configuration...
Current configuration : 2768 bytes
! Last configuration change at 06:26:04 UTC Thu Jan 15 2015
! NVRAM config last updated at 06:13:25 UTC Thu Jan 15 2015
version 15.1
no service pad
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$WGaR$ENClKInCBHeG29OzoldeB1
no aaa new-model
dot11 syslog
dot11 ssid nes
vlan 1
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 0 XXXXXXXXXX
ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp excluded-address 192.168.2.1 192.168.2.100
ip dhcp pool lan
network 192.168.1.0 255.255.255.0
dns-server 4.2.2.2 8.8.8.8
default-router 192.168.1.1
ip dhcp pool wifi
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip cef
no ip domain lookup
no ipv6 cef
username admin secret 5 $1$H7H9$NOkVjNhVk34i.mcWLwWX01
bridge irb
interface FastEthernet0
switchport access vlan 2
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
speed 100
full-duplex
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers aes-ccm tkip
ssid nes
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
ip nat inside
interface BVI1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list INSIDE_NAT_ADDRESSES interface FastEthernet4 overload
ip access-list standard INSIDE_NAT_ADDRESSES
permit 192.168.1.0 0.0.0.255
permit 192.168.2.0 0.0.0.255
control-plane
bridge 1 route ip
banner motd ^C
========= DO NOT LOG IN =========
^C
line con 0
exec-timeout 0 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
password XXXXXXXX
login
transport input all
ntp server 198.27.65.66
end
01-20-2015 01:58 AM
If I have not misread, but why dont you simply put the LAN ports on the same vlan 1? If that is possible, then have the end devices that belong to VLAN 2 rebooted/DHCP renewed.
No/yes?!
