Trying web access with Nat and Static routing not work ?
aymango
GNS3 Version: GNS3 v2.2.29,GNS3-vm v2.2.29
Operating System: Windows
hi every one
gns3 topology contains A cloud bridged on my host connected to cisco iol layer 3 router which is the gateway to another network started with a fortigate kvm unit and its internal network
NAT ,Dynamic NAT and PAT were tried with static routing on both side  trying to access the fortigate unit on web access from my host and it is not working
any help/ideas with thatfortigate.PNG
5 Replies 5
Hello
Just to confirm , you are tring to access the Fw from a host located in the cloud breakout  and youve applied NAT on the internet router between the cloud and that Fw?
Can you post the internet router running configuration please
Kind Regards
Paul
friend, there are many issue relate to use Host vis Bridge Cloud
I prefer you use FireFox appliance instead
it can give you HTTP to FortiGate
thank you for help
my topology is a host with a gns3 and it's vm installed which contains a topology as attached photo
cloud ----router ---- fortigate kvm
i want to access the fortigate unit from the host (holding all the virtualized environment ) through the iol layer 3 router
what VMware you run
if you run VMware player then there is file missing you need it
