turning off unused service for router security baseline.
a.oboyle
when configuring a router for a security baseline, and entering the command no ip domain-lookup, the terminal session and the router both hung. router is a 3745 using (C3745-JS-M), Version 12.2(13)T5 IOS. what happened. had to power cycle router to restore service so log files are gone.
Not applicable
Try to upgrade the IOS version. Advanced Server requires turning Terminal Services off. See your Microsoft documentation. Reload the router which takes corrective action.
I would think that it is very strange that no ip domain-lookup would hang the terminal session and hang the router. Is the symptom reproducable? If so I would suggest opening a case with TAC - and would also suggest upgrading the code to a version which does not do this.
Rick
Rick
