ā02-28-2011 04:24 AM - edited ā03-04-2019 11:35 AM
Dear Experts,
Based on the business requirement, I have installed one more 9 port FE Switch in addition to existing one, NM is discovered but when we connect PC or IP-Phone it is not working, current IOS is flash:c2800nm-advipservicesk9-mz.124-3h.bin with 64MB Flash, need your valuable advises.
ā02-28-2011 04:52 AM
I suppose your using DHCP for your PCs/phones? And they must be in a different VLAN?
Could you post running config please and tell us more about the problem.
Regards.
Alain.
ā02-28-2011 10:10 PM
Dear Cadetalain,
Appreciate fro your feedback and thanks for your support.
Please find below the config.file
Problem: PC & IP Phone are working with one 9 port switch only, if i install both at same time it showing and even the inteface is also UP but PC & Ip Phone is not picking up any IP.
Waiting for your feedack.
Reagrds,
JA.
ā02-28-2011 11:31 PM
ā02-28-2011 06:53 AM
If you install 2 of these switching modules, you need to stack them externally using an ethernet cable. Also you can only have amaximum of 2 switching cards in the router. If you have 2 9 port cards plus an NM, it'll never work.
Take a look at the Q&A here http://www.cisco.com/en/US/prod/collateral/routers/ps5853/prod_qas0900aecd8016c026_ps5854_Products_Q_and_A_Item.html
Especially the question about Intra-chassis stacking
james
ā02-28-2011 11:29 PM
Dear James,
Appreciate your feedback & support.
I have read the doc which u send, i will work on that & will let u soon.
Thanks & Regards,
Jaleel
