11-16-2016 10:09 AM - edited 03-05-2019 07:29 AM
We attempted to add this ACL to two of our ars's:
ASR1000 Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.4(2)S1
| ip access-list extended RIMINIvegas |
| permit ip host 204.63.59.37 host 136.179.14.60 |
The router has another acl with the same host IP address -
ip access-list extended TSYS
permit ip host 204.63.59.37 host 206.209.38.55
After adding the RIMINIvegas acl, with no errors we see this in the config:
Any ideas? Is a TAC case required?
11-17-2016 06:46 AM
Here are a couple of ideas which I hope may help.
- It should not be a problem to have two access lists which both contain the same host IP address. Whether they work as expected depends on how the access lists are applied.
- Would you post a screen shot of the command line input and output as you configure the access list RIMINIvegas
- Would you then post the output of the command show access-list RIMINIvegas
Rick
11-17-2016 07:03 AM
Both ACL's are for IPsec tunnels. This router has 8 tunnels in production with no issues. This ACL is in the config after we enter it.
This is the command string, (removed the IP addresses and router name for security reasons)
| permit ip host x.x.x.x host x.x.x.x |
Phase 1 of the tunnel comes up, then goes down, and the permit statement disappears. My peers though I was crazy so they tried it again last night.
Same result.
I can't post the commands as I enter them, we have strict change control, but I can assure you that the commands work, and there are no error messages.
Output of sh ip access-list
router1#sh ip access-list RIMINIvegas
Extended IP access list RIMINIvegas
router1#
TAC case time!
11-17-2016 07:38 AM
Am I understanding correctly that after you enter the commands that the permit statement does show up in the access list and then when the VPN tunnel attempts to come up that the permit statement disappears from the access list? If so it certainly is TAC case time.
Rick
