two cisco router with VPN
mohammady
I have two cisco router connected to each other by E1 connection ,also I implement a VPN between them (VPN over E1),one of these routers is connected also to the internet but when I tried to reach internet from the other router I could not>>I did a trace route from the router that is not connected to internet to real IP address but i could not reach(the default route on this router is toward the router connected to internet)
Any help??
rais
Level 7
Level 7
You may have to post your config.
The NAT statement [if required] on the Internet facing router should include the source space behind the other router.
The VPN is for the inter-site communication or for all traffic?
Thanks.
forget about nating..trace route to real IP from the router that is not connected to internet was not successful????what you suggest
What does the traceroute show you, does the path try to go via the tunnel or via a default route?
the default route is through VPN Tunnel
