two directly connected mulilayer switches and adjacency table.
sarahr202
Level 5
Level 5
Hi everybody!
let say we two switches(L3) connected to each other by F0/1 on both switches, assume that cdp is disabled, no ip packet has been sent by either switches.
In such case, would switches have entry (next hop--mac to mac) in their adjacency table for each other.
If yes, is it because of keep alive messages?
thanks a lot!
Giuseppe Larosa
Hello Sarah,
under the conditions you have described the two L3 switches should be unaware of each other:
if CDP is disabled
no ip packets has been exchanged this includes IP routing protocols
unless they are exchanging IS-IS PdUs (that are not IP packets) they don't know of each other
keepalives are L2 only but near to L1 used to understand if the interface can be seen as up/up (line protocol up)
so they cannot carry information like IP to MAC mapping
As soon as you try to ping the other side both switches can build an entry for the other one.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sarah,
if CDP is disabled
Hope to help
Giuseppe
