two interface in one router connect to two L3 device as Load balancer or FW
engahmad8
Dears
I have one router connect to ISP and I have 2 L3 devices
I need to connect this router to it
IP subnet between this 2 device should be same
however, need  to configure two interface to connect both L3 devices
I need your help with out using switch between router and L3 devices
5 Replies 5
post a schematic drawing of what you want your topology to look like...
you can see topology in attach file
Hello
Your topology attached doesn't replicate the setup you stated?
Kind Regards
Paul
this digram is represent with two ISP
we can ignore isp 2 router and look to isp1 router with both f5 LC
update digram
